Steering rear seals
Tim in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in MN Quote  Post ReplyReply Direct Link To This Post Topic: Steering rear seals
    Posted: 23 Jul 2010 at 10:04am
Still fixing little things on my 52 WD, I filled up the steering gear with the 140 wt grease that the manual calls for.  I noticed the other day that it's leaking out slowly from the steering shaft.  The parts manual calls for cork seals for the steering shaft seals, is there anything else you guys use to fix this problem?  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 10:52am
Mobile EP grease or something similar. It's either that or disassemble the unit and find and repair the problem. You might be able to find a thinner rubber seal to replace the original and put 2 in place of the original.  Charlie
