5050 injector pump
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Topic: 5050 injector pump
    Posted: 22 Jul 2010 at 7:32am
Talking on a deal for a 5050.  Injector pump took a dump.  Can it be rebuilt, or are replacements available?  Any idea on costs?  Thanks for your help!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 9:03am
that injection pump should be rebuildable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 6:43am
I guess either no one has had to rebuild a pump or no one owns a 5050.  I would have thought I would get a few more responses.  At least what brand is normally on these tractors.  I sure wish I could get a little more info before I go look at it.
Thanks, John
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 7:20am
we would need some more info before we could help you.  Like a photo of the pump I think they used cav pumps on 5040 and 5050.  Your best bet is to pull it and take it to a pump shop  and have them test it.  Plus did you take any lines off to see whats it doing ?  How many hours are on the pump ?  If nothing major a rebuild should be under 500 bucks  plus if your buying a non-running 5050 how long has it been sitting ?
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 7:34am
Kip,  Thanks for the info.  It hasn't been sitting too long.  The guy says we should be able to get it started with ether.  All I have seen is one pic of the tractor and for the price it looks like a good deal.  I would think it's an original pump, and I didn't get the hour reading, will look when I go check it out this weekend.  Thank You.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 8:48am
I also though those were CAV pumps. post the numbers off the pump.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 10:51am
any pump off a Long 360-460 2360 2460 2510 - all Fiat or 5040 5045 5050 are the same CAV pump.  prices 650-750 rebuilt or some new.  tx14947 tx 10417 tx 15803
