Catalylic convertor gurus
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: Catalylic convertor gurus
    Posted: 06 Nov 2018 at 7:33pm
 Well,,on the little Nissan Frontier I picked up,,I noticed the MPG was not too swift and just kept gettin worse. It gettin bout 11 MPG now and thas a 4 cylinder with 5 speed  and gentle drivin,,!!!
  Was drivin it to go vote and the check engine light come on so I went and voted then drove to O'Reillys and they tell me the Catalytic Convertor is pluggin up,,,,WTF,,?? The dang trk only gots 145,000 miles! So, I stop at Autozone and they tell me the same thing ,,,HMMMmmm?? new convertor is $170,!!   holey CHIT,!!
 Anybody got any suggestions ,,seems like I read somewhere that you can drill into it and drain the catalyst and be good to go,,,,!! Failing that,,,any kind words of wisdom. Bye the way NM is not like californy and NO check stations,,,,Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 7:49pm
aftermarket cats should be cheaper...
also they make 'test pipes' that fit where the cat was.....
Les Royer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 7:50pm
I feel yer pain Joe.
I'm a little upset my 4.9 in my brick nose 4x4 only gets 11-13. But I need to find a site where I can calculate my non stock tire size with those 31/10.50-15 tar's on there. Maybe I'm coverin more ground than the odometer says. That Nissan all stock or do you got it all jacked up where you can see Nebraska from the drivers seat?
I still gots my A/C but it's clear out in the barn now.
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 9:44pm
Cut exhaust pipe off right after cat. Drive somewhere you won't mind a mess. Take a big long rod and 4 pound hammer. Drive rod through exhaust pipe. Start vehicle and watch platinum pellets fly out the back. Use s clamp to reseal exhaust pipe
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
1955CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 10:05pm
LOL LOLLOLLOL
Yep, mine are gone and have cheater pipe in their place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 11:45pm
Oh MY!! EmbarrassedOuchWacko
The test pipe does the trick...BTDT....
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 3:22am
 I checked out some YouTube videos and most people use two of the spark plug non-foulers and screw them into the collar where the sensor was on pipe and that "fools" the ECM when the catalyst is rodded out or cat replaced with one of those test pipes,,,,,
 I'm gonna pull the cat in the mornin cause it gots flanges on both ends,,,,,and then,,,,and then,,,,I'll make sure and wipe off any ,,,,"Incriminatin evidence",,,,er,,,just make sure it looks unmolested,,,,,,I'm outa here,,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 3:31am
That’s what you get when you have a vehicle controlled by a computer 👎
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 6:35am
yeah ..computer...sigh.. 99 CRV  blew out the front O2 sensor , so 'mechanic' replaced with after market one..too lazy to use old one....time passes ..engine light comes on... 'cat not rdy'..I dig into it..seems the computer 'gurus' set the trip points in the computer a tad 'fine' so you need the $$$$ O2 sensor. I tried another after market one( $20 delivered) and it was OK for awhile. Sad thing is there's NOTHING wrong with the cat( it's new), just the computer program. I timed it just right this year..got all lights off, computer happy, had E-test done( they just read computer..NOT gases coming out), so good for 2 more years.
Jay
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 7:08am
Your computer will never be happy with a test pipe or a hollowed out cat. Put a can of sea foam in a half tank gas and drive it hard. You can remove the cat and fill it with very strong hot water and dawn soak and reinstall. But that's a lot of work. I hate exhaust work so tommorrow I'm taking my $250 Pontiac transport beater in and having a new exhaust installed. It'll cost as much as I paid for the car but it worth it.
Edited by Dakota Dave - 07 Nov 2018 at 7:10am
weiner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote weiner Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 8:15am
That’s what you get when you have a vehicle controlled by a computer 👎  Dittos!
Real heros wear dogtags, not capes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 8:28am
 Well,Dave,,,I was gonna take the cat off,,,either for clean out or rod out. I checked out several YouTube videos on cleaning em out with some of ole Shameless's favorite stuff,,,just plain old Vinegar,,,ugh,,,,,,,they show pics of before and after and looks like the vinegar does work. I'ma try that first but,,,,but,,,me bein a person of short patience,,,if cleanin with vinegar don't do the trick,,,,it be out with the crow bar,,,,,,,,,WinkWink
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 9:31am
The last one I did, I used a long 1/2" extension  and rammed it in and dumped it out til it was empty.  Unfortunately you can't buy the test pipes anymore, at least in MI you can't.  If your handy, you can make one and weld it in place.  The problem you run into now is they are attached to the manifold so if you want to replace it, you'll need a pipe with a flange on one end.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 10:57am
I thought that I read once (maybe even on here) that the platinum in those catalytic converters is some valuable stuff. Is there anything to that. ..? Darrel
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 11:06am
Scrap prices listed for different sizes etc. Rockaway Recycling, NJ.
Need to also check your state regs on doing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 1:04pm
 Back when the price of junk iron and aluminum and all was all so high,,there was this group of locals that were scavanging the cats off parked cars and trucks. They carried generators with saws alls and was just cuttin em off the vehicles. Then when that dried up they were actually stealin em off operating cars. I got asked several times if I wanted to sell the cats of our two vehicles. You even seen em for sale in the want ad papers,,,,,,don't have any idea what the platinum was sellin for  Tho,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 4:11pm
the platinum is only valuable if its still in the converter. Its illegal  for a recycling location to except your platinum if its out of the converter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 8:01pm
I've only taken one cat in for scrap. Don't know what it was off of an it was pretty good size and they gave me 70 bucks for it
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 8:17pm
 Well,,I got under the Nissan trk this mornin and,,,,and,,,the friggin catalytic convertor has already been replaced with a piece of exhaust pipe,,,so,,WHAT THE HECK TRIGGERED THE CHECK ENGINE LIGHT?? I checked out some more YouTube videos and see where some people remove the second sensor and install TWO of the old timer "Spark Plug Non Foulers",,then reinstall the sensor in the top non-fouler after drilling it out where the sensor will fit inside the non fouler,,,Done it all like they said and fired thet mother up and ran it down the road plumb to the county line road and back just as fast as I wanted to,,,,and,,,and,,,believe you me,,that dang engine started to run smoother and smoother with more power the more I drove the piss out of it,,SO,,I done it again just for good measure,,,!! I am impressed with the difference in the engine now,,!! And the check engine light never offered to come back on,!!
 Ole Shameless is gonna be impressed now but he won't mind that the price on the trk just went up a bit,,,and him wantin it so bad,,,LOLLOL
This page was generated in 0.969 seconds.
