In Augeration
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Topic: In Augeration
    Posted: 21 Jul 2010 at 10:23pm
My auction bought post hole auger took a krap.
On the fifth hole.  I took it apart the other day.  The cast gearbox has a cracked bearing mount thingy - I don't believe it is curable.  Someone a week or two ago showed a pic of a similar one except a SC model.  Someone wrote in it was sold by Tractor Supply in the 60s.
I cannot find a name on this box or anywhere, whoever made it isn't very proud of it.  If anyone has a parts unit they would sell or know of anyone that has parts or any other info please lemme know.
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 9:18am
bumpity bump bump
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 9:41am
I have 3 of them in Ohio, I think.  They look close but have the old style lift.
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 10:28am
R Aiken,
Any chance you could measure the length of the handle? Mine is missing the handle. I am still looking for what type of lower mounting brackets that are used for the CA.
Thanks,
Mike
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 10:44am
Originally posted by mnoonan-NEWI mnoonan-NEWI wrote:
R Aiken,
Thanks,
Mike
The handle is 4 foot long. It looks to be 1/2" black pipe with a bicycle hadlegrip on one end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 8:21am
another one in Ohio,  phd craigs list
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 8:58am
R Aiken, Thanks. Mike
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 9:08am
I like the optimism.....
he says " NO SPAM PLEASE "..... like the spammers really care!!!  LOL
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 10:36am
Post a picture of the cracked 'bearing mount thingy'... did it tear teeth off the gears, or just spin the bearing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 5:29pm
Dave -
Teeth okay - strangely enough, the pinion and ring gear look cast.  I never thought something like that would be cast, but it sure looks that way.  They both look okay.
The bearings are okay as well, there is sort of "tab" that hangs down inside the box that carries the nose of the input shaft, supports the bearing.  That is what broke.
R Aiken - would you be inclined to sell parts?
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 8:00pm
Originally posted by Creek Jenkins Creek Jenkins wrote:
Dave -
cheers,
Creek
Yes I would sell you a gearbox. Send me the masurements and I will see if one fits and is good.  Richard
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 8:54pm
Well, post a picture of the thing, showing the broken tab... if there's a way to correct it, I'll bet someone (perhaps me) will be able to do it...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2010 at 8:55am
When I get home tonight I will take some pics of the broken part and some measurements and we will see what happens!
Thanks and cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2010 at 2:32pm
Here are some pics of the auger gear box:
Edited by Creek Jenkins - 30 Jul 2010 at 2:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2010 at 2:39pm
Here are pics of the broken parts and a view inside the box.  You can see the tab thingy that used to hold the nose bearing for the pinion.  I think what may have happened is the little cylinder thing might be part of a pin holding the ring gear to the shaft - it sheared and got in between the pinion and ring gears and something had to give.
cheers
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2010 at 2:44pm
Richard - here is a drawing of the gearbox, lemme know if it matches one of yours.
cheers
Creek
This page was generated in 0.168 seconds.
