200 Proper Operation
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Topic: 200 Proper Operation
    Posted: 03 Nov 2018 at 10:49pm
Been pulling logs with the 200 cleaning up a fence line. My question is do I have to shift power director to neutral before shifting gears? I wasn't sure if I was going to tear something up so I would shift to neutral on the power director then push in clutch then shift to reverse let the clutch out and then engage the power director. Is this overkill or the proper way to operate the tractor? Or if I am not under a load can I leave the power director in low and just push the clutch pedal and shift the transmission?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2018 at 10:51pm
no need to do anything with PD when changing gears.Just clutch and shift
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 7:46am
Just make sure the tractor is stopped and trans have stopped moving before shifting so you dont grind the gears. Gear grinding will cause it to be a gear jumper if practice is continued.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 7:58am
Get an operators manual. It will guide you through some of the intricacies of the tractor, including how to shift properly.
Wink
I am a Russian Bot
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 9:54am
on a 190/200 if the pd linkage is set right, you can shift the gears without pushing the clutch pedal down, just put pd in neutral. But, out of habit, most of us just use the foot clutch, and doing that the PD can be in any of it's 3 positions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 11:58am
Exactly right! If nothing is in a bind they shift smoothly with the main transmission ,, no foot clutch involved
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 3:37pm
Have never heard a 190/200 could be shifted without pushing in the clutch pedal. My operators manual clearly states tractor must be at a stand still with clutch pedal depressed before selecting any gear. “Always stop the forward motion of tractor before changing from one gear to another. Never attempt to shift gears on the go as excessive gear clashing may result.” Can it be done? Yes but you may have a gear jumper some day. I prefer to avoid that.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 4:33pm
My old round baler(Vermeer 605F) you have to back up and shut off PTO to eject the bale and I have baled hay all afternoon with my 200 with HYD. PTO clutch and never ever touched the foot clutch while shifting gears with no gear grinding what so ever. Same deal with the old D-17 ser.3 except for engaging the PTO. Been doing it this way for 40 years. The gear shift must be made quick and as soon as you put PD in neutral and come to a COMPLETE stop. Saves time and wear on throwout bearing and clutch. May not be "owners manual" approved but if PD is working properly it works perfect even if PTO is running.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 7:33pm
I know you are not suppose to but like Ky.Allis I have done the same thing. I have a XT and a Vermeer 605F baler and I make 3 or 4 bales to get the oil warm then just use the power director. Been doing this since 1988 and no problems
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 8:37pm
I’m a little confused, are we talking about shifting the power director on the fly which is how its designed or actually shifting gears with the tractor stopped, power director in neutral, using no main clutch, and shifting say from 2nd to 3rd or to reverse?? Not using the main clutch pedal? Just want to make sure I understand correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 8:54pm
When baling I shift from 3rd to reverse then back to 3rd. once oil is warm I just use power director. I have old baler and have to back up and turn pto off every bale. To save time I back up while tying the bale
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 10:07pm
Explained pretty well. Yes the no no you fear is what they do.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 10:55pm
I guess That I can join the ranks of the "bad shifters" too while round baling. I've done it hundreds of times. When I get a full bale, I'll put the PD into neutral, get the twine arms to tying while coming to a stop. After being at a dead stop, and while the bale is tying, I'll make a quick shift from 3rd (5th/6th, by the decal) to reverse, feather the PD back as to back the tractor up 8 to 10 feet. The with the tractor stopped and PD back in neutral, shift quickly back to 3rd. When the bale is done being tied, kick it out, pull PD back as to move the tractor and baler ahead far enough for the tailgate to clear the bale, PD back to neutral, drop endgate, pull PD back and make the next bale. Never touch the clutch pedal for the whole process. Take in mind that I only do this when every is warmed up good, I shift it very quickly, but not brutally, and if I am at a stop with the tractor, and the main transmission is in neutral, then I will ALWAYS use the foot clutch to put it in gear. And then only after I've stepped on the clutch and given the transmission a couple seconds to stop spinning. I've never had any gear clashing or grinding by doing this. And if you re-played this whole scenario, and stepped on the foot clutch to do each shift I described, imagine how hard that would be on the dry transmission clutch when you consider that it would also be starting the PTO , which is turning a full bale, each time you engaged the clutch. Darrel
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 1:03pm
There is no way you could shift my 200 without using the clutch. Some of you guys must be lucky.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 2:23pm
I pull a 15’ batwing brush hog and sometimes it ends up on the 175. I have gone from 2nd to reverse and back many times. I’d hate to imaging waiting for that brush hog to stop spinning to shift. As said before it’s has to be quick. It doesn’t grind at all.
bauerd44 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bauerd44 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 2:45pm
My Son bales with our 185 and he stops with the PD, changes to reverse without the foot clutch and backs up 5-10 feet, stops with the PD and drops the bale.  back to 3 without the foot clutch and back to baling.  The New Holland baler we have does not require the PTO to stop.  Sometimes he throttles back and get a drink and wipes his brow.
When we used the 175 on a smaller baler, before the 185, we did the same thing with the PD and shifting gears without the foot clutch.  Again as previously stated, the transmission and PD need to warm up.
I watch a buddy bale with his green thing, and I can't imagine holding the foot clutch down for every bale while tying the bale.  My leg would give out after 8 or 10 bales.
Dale
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 2:55pm
Dale
Well, Allis quit building them that way.  We bale with a 7045 Power Director, and you have to hold the foot clutch down for every bale.  Or I suppose you could pop it out of gear while you wait.  But no neutral in the PD, either in hi or low, and when you step on the clutch it goes to low of course.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 5:42pm
I thought the 7000 series had an independent pto ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 6:07pm
They do. He means they no longer have a both, a foot and hand clutch so to speak.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 3:02am
Since we're on the subject of round baling. With my 7010 Power Shift can I just down shift to neutral and stop with the brakes to finish a bale without clutching?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 6:17am
Right, I'm just saying you have to either hold in a foot clutch, or shift out of gear and back into gear, using the foot clutch, to tie a bale.  No PD neutral, but yes an independent PTO.
nick121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 7:35am
Is it me or do the 100 series allis tractors seem like a confusing setup? not knocking them because I'm sure they are great tractors and I do love my allis equipment. But just seems like an awkward setup. My 7040 pto can go into gear at any time and doesn't matter about the foot clutch or stopped or moving, same as my old massey 165.
Am I misunderstanding this? does the pto stop when you clutch in on the 100 series?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 7:35am
Yes
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 7:47am
Yes but if you have the hydraulically engaged PTO like many have then you didn't have to clutch to engage the PTO. If you grew up on them you learned to like that set up for most things because if you needed to stop everything for an emergency quick you just stepped on the foot clutch vs trying to find the lever with your hand.
Edited by Lonn - 06 Nov 2018 at 7:48am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 8:29am
Yes I can see that being nice to quickly stop everything. Guess it's just different from what I'm used to that's all.
ezlle71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ezlle71 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 9:45am
I  always understood that the power director aka hand clutch was allis's answer to live PTO. And it stems back to the rotobaler. I round baled with my XT ths summer and shifted just how everybody said here, PD neutral quick in reverse back up and then same back to 3rd and forward
190XT, 185, D15 SII, 7040 is living again, 7010 retired for parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 10:26am
Never operated a 100 series.....So, dumb question....Why does the shift have to be "quick"?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 10:29am
Technically an Allis Chalmers WD has "live pto". An Oliver 77 or Cockshutt 30 had "independent pto". There is a difference.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 10:31am
My guess is that you'll grind gears otherwise. I just clutch per manual as needed and use the PD for hi/lo shifting and hold in neutral when needed.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 10:52am
When shifting main trans gears while only using the PD neutral position, the shifts need to be made quick because the wet clutch packs can drag slightly and cause trans gears to rotate. So leaving in gear keeps anything from turning, so going into neutral, and right to next gear, the shafts don't have much time to start rotating. You put PD in neutral, then main trans in neutral, the trans will be turning it's shafts and gears enough that it will likely grind when you try to put it in gear.
