Gleaner L3
Hopper_68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hopper_68 Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner L3
    Posted: 02 Nov 2018 at 12:58pm
We just bought a 1983 L3 we went to cut beans and have no header hight control. Anybody know how to fix this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 1:24pm
Down by the gearshifts there is a LOW-MED-HIGH knob. Try it in each position. The header has to be running and engine throttled up. There is a 10 amp fuse for AHHC that could be blown--replace with a 20 amp.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 3:33pm
IF the basic check Doc posted doesn't work - do these checks - with a test light you should have current on the 3 springs on the RH side of the head on the big plastic rotary switch the middle is mid - others are low/high - (this does not make the header cut higher or lower) Then the brass bar will touch the springs and send back current thru the blue wire to raise or the red wire to lower. Check at the switch and the plug in for the header - at the plug in there is a jumper on the red lower wires and BOTH red wires have to have feed back current to make it lower. Many times the wires will break INSIDE the harness where the throat pivots and you get input current to the control module at the switch but it never makes it back to the module.
The module has to have power from two sources The orange wire then the red/yellow wire to the module.   The HIGH MED LOW switch also had to receive power /volage as well from the orange out power wire to the switch.    The early modules were not sealed - few still exist and they had only one power wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 10:34pm
Wires also brake where they go around rear corner of header and on back of header switch.     MACK
This page was generated in 0.037 seconds.
