Allis G engine rebuild.
hinzec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hinzec Quote  Post ReplyReply Direct Link To This Post Topic: Allis G engine rebuild.
    Posted: 01 Nov 2018 at 10:21pm
I am trying to reassemble an Allis G engine. I am have trouble figuring out the brass thrust washers on the crank. When we disassembled we only found one partial washer in the oil pan. I see the outer washer is held in place by pins. What holds the inner one from spinning? There are no pins, or holes where there should be pins. I also may be in need of the crank gear, the oil slinger, steel shims and the steel thrust plate.
Thanks in advance for any help anyone can provide.
Edited by hinzec - 01 Nov 2018 at 10:21pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 11:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote hinzec Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 7:52pm
Thanks Gerald it sure will.
