Allis 8070 vs White 185
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Topic: Allis 8070 vs White 185
    Posted: 01 Nov 2018 at 8:43pm
How does an Allis 2WD out pull a White FWA?
Look at the total drawbar pull (max)
Does anyone have/had a White tractor to comment?
Allis 8070
Test Date:     September 1 - 16, 1982
Type:     Diesel 12-speed 2WD
PTO power (rated engine speed):     170.72 hp [127.3 kW]
PTO fuel use (engine speed):     10.7 gal/hour [40.5 l/hour]
PTO power (rated PTO speed):     171.44 hp [127.8 kW]
PTO fuel use (PTO speed):     10.4 gal/hour [39.4 l/hour]
Drawbar power (max):     145.36 hp [108.4 kW]
Drawbar pull (max):     18,777 lbs [8517 kg]
Max pull gear:     2S
White 185
Test Date:     April 5 - 18, 1988
Type:     Diesel 18-speed 4WD
PTO power (rated engine speed):     187.55 hp [139.9 kW]
PTO fuel use (engine speed):     10.9 gal/hour [41.3 l/hour]
PTO power (rated PTO speed):     192.38 hp [143.5 kW]
PTO fuel use (PTO speed):     11.1 gal/hour [42.0 l/hour]
Drawbar power (max):     163.56 hp [122.0 kW]
Drawbar fuel use (max):     10.8 gal/hour [40.9 l/hour]
Drawbar pull (max):     18,318 lbs [8309 kg]
Max pull gear:     2-over
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 9:27pm
Likely slightly lower hearing in the allis.
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 7:18am
The speed at which max drawbar pull was measured makes a big difference.
Wink
I am a Russian Bot
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 7:21am
Being tested on pavement takes a lot of the FWA advantage away.  And what were the ballasted weights when tested?  Most tractors test very close to tractor weight = drawbar pull, depending on speed/gearing like Lonn said.
In other words, if the Allis was heavier in Lbs./ HP ratio, and pulling slower speed, the numbers make sense.
Edited by Tbone95 - 02 Nov 2018 at 7:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 7:27am
The 8070 weighed 22,370 lbs total with the rear wheels weighing 17,830 lbs. The White only weighed 18,770 with 10,935 on the rear tires.  Cement surface doesn't mean an FWA will do better, especially when it weighs LESS. The truth is the White had almost 20 MORE drawbar HP at a higher ground speed. You've gotta know what you're looking at when it comes to these tests.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 7:32am
same way the WC out pulled the UC in nebreska tests
