Model G oil pump
Jerry (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerry (KY) Quote  Post ReplyReply Direct Link To This Post Topic: Model G oil pump
    Posted: 01 Nov 2018 at 3:25pm
I have restored a 1949 Model G.  I am not getting any oil pressure or oil circulation. The oil pump is running backwards. How can this be?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 3:49pm
What makes you think it is running backwards?
Take the plug with the slot in it and see what is behind it. If you have not had it out it could plugged behind the plunger.
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 5:49am
Try priming the pump where the oil pressure gauge is installed.
Remove pressure gauge and squirt oil in with an oil can to prime the pump.
Reinstall the pressure gauge and give it a try.
The Allis G like the Farmall Cub have the oil pump located a distance above the oil in the oil pan. A dry pump has difficulty pulling oil up from the pan. Squirting oil as describe will fill the pump with oil.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 9:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 9:59am
The ONLY way oil pump can run backwards is if teh engine is going backwards... as far as I know...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerry (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 10:05am
Sorry, it is not running backwards. I was looking at it the wrong way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerry (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 10:10am
I have the engine pulled apart now to look at the pump. Everything looks good. Will reassemble and try to prime the pump as you suggested.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 10:39am
intake screen must be turned to front of engine or it can get air in it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerry (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2018 at 9:51am
I have reassembled the engine and attached it to the tractor. Primed the oil pump as suggested and fired it up. Running like a champ with good oil pressure. Thanks to everyone for the help.
