I-400
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: I-400
    Posted: 31 Oct 2018 at 7:48pm
I need to know where the coil mounts, the usual place is taken up by the power steering pump oil reservoir. Anyone have any pictures?
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 9:24pm
It mounts on top of tank with a metal strap where the tank mounts, flat as opposed upright normal position.  I have seen with one piece tank and coil mount to rear but it gets in way of the plugs.
I have seen one that mounts flat on top of tank, had a cutout to go around the filler pipe and point to rear, coil sets with coil wire is to the right side.  I thought I had one of these but could not find it today.
  I'll look for a picture.
Edited by JoeO(CMO) - 01 Nov 2018 at 9:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 12:58am
The proper factory mounting for the coil on thactors equipped with the hydraulic reservoir mounted on the right side of the motor is another bracket is used. This puts the ciol back behind the #4 spark plug. The parts book will showthis extra bracket. I may have one available. I’ll takea look after work later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 8:53pm
I have the bracket just didn't know where it goes
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 9:04pm
what does the bracket look like?  (I know it would look like a bracket, but need more description).
