A Pepsi Challenge |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Topic: A Pepsi ChallengePosted: 31 Oct 2018 at 6:04pm |
I have four inch guttering. I need to punch a hole in it for another down spout. I have seen the tool to do this but i hate to do the 50 buck service call to have one punched in. How would you all go about this from a farmerized perspective?
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90826 |
Posted: 31 Oct 2018 at 6:08pm |
air or electric grinder with a 4 inch cut off wheel.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Posted: 31 Oct 2018 at 6:47pm |
Hole saw and compound aviation snips. Tracy
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1014 |
Posted: 31 Oct 2018 at 7:09pm |
Hammer, chisel, duct tape. And probably a band-aid.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34624 |
Posted: 31 Oct 2018 at 7:25pm |
Shot gun, BLAM, hole made, now to finish with circular tin snips... if there's anything left
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
Grayray
Joined: 12 Sep 2009 Location: Ambridge PA Points: 3860 |
Posted: 31 Oct 2018 at 7:32pm |
Draw out the area you want to cut out. Use an old beat-up wood chisel to punch a hole in the center then use aviation snips to cut it out. This is all I ever used when doing gutters and downspouts, I've done hundreds of them this way.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 31 Oct 2018 at 8:43pm |
Ask Shameless to redirect his 'machine'...there now you don't have to make another hole cause it's all covered with that white stuff he loves to share....... neighbour just upgraded his troughs from 5 " to 6", didn't know 4" was still around..you don't get a lot of rain ?? up here 'tin whackers' must have got their nickname by the way they install .Whack a screwdriver through the gutter, hack with snips,use 1/2 tube of sillycon to seal. The sad thing is I can use a proper die set in LESS time and do the job RIGHT. Jay
Dave H
Posted: 01 Nov 2018 at 8:21am |
Well glad i asked, I m going to start with Tracy's suggestion with the hole saw. Why didn't I think of that? Well maybe they re 5 inch, I did not measure before I opened my pie hole.Thanks folks.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12420 |
Posted: 01 Nov 2018 at 8:45am |
PERFECT!!!!
john(MI)
Posted: 01 Nov 2018 at 9:15am |
It appears on mine they just cut an X and folded the tabs down into the downspout.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 01 Nov 2018 at 1:13pm |
