Allis 226 vs Leroi 226
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Topic: Allis 226 vs Leroi 226
    Posted: 29 Oct 2018 at 8:28pm
Can anyone tell me the differences between these two engines?  Is there any parts interchangeability between the two engines?
Edited by TedBuiskerN.IL. - 29 Oct 2018 at 8:29pm
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 8:32pm
Ted,  I wish I knew.  I do remember having a person come to our parts department in my father's dealership and state he needed a water pump.  I looked it up for him and I do not think it was what he wanted.  Come to find out that he was looking for a part for a Leroi engine.
Take good care.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 8:35pm
Someone will know. Look like twins don't they? Can't remember what I once knew.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 10:03pm
If I remember right, combustion chamber is in the head on the LeRoy, connecting rods are longer too.
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 12:19am
I rebuilt the Leroi D226 in my air compressor (number 4 rod bearing spun), the crank has extra weight on it and the rod caps for the crank are at an angle where the 45 rods are square to the rod.  I used a 45 crank and rods.  The Leroi engine had 4" flat top pistons.  So I used a 4 1/8" overbore flat top WD sleeve and piston set.  You must use the spark plugs for a Leroi D226 engine though since they are a little shorter and the standard 45 plugs will hit the pistons.  In the end if you are just doing a simple overhaul, you can order the WD overhaul kit and everything should work.  I never compared the journals on the cranks to see if they  are the same size on the rods (mains are the same), but the cam bearings and all the other parts worked on the engine, had one issue with the oil hole on the center cam bearing not lining up to send oil to the rocker shaft and had to drill an oil hole for it to lube the rockers.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 9:49pm
Combustion chamber in head, longer canted rods, slightly different external castings and parts like water pump, timing cover, etc. Beyond that, not sure on specifics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 8:14am
Thanks everyone, I knew there were some differences, but they are twins to the Allis engine, so I wondered what the difference were.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 3:33pm
I never heard a simple explanation as to whether the Leroi engines were built by Allis; or were the Allis engines built by Leroi? Or perhaps were they designed by the same outfit?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 6:52am
Allis poured some of the castings for LeRoi
Wink
I am a Russian Bot
This page was generated in 0.285 seconds.
