grader length ?
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Topic: grader length ?
    Posted: 29 Oct 2018 at 7:40pm
Anybody have an idea as to how long is the D graders? ---Need to send truck after mine, it got stranded 45 miles from here and I got to get it home! Might can get the tow truck guy with his rollback unit but I need to know how long the bed would need to be to hold it. weight/width no issue, just the length!  Thanks in advance!! ac fleet
DavidnTenIll View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 8:26pm
I think there was a post on here some years ago that said 20ft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 8:42pm
An 18' bed can do it, if you back the grader on, drop the blade, and let the front wheels dangle...Wink
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 8:39am
   Hi. 19ft-0" +/-.    I hope that this is not too late to help you.   Ross.[/IMG]
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 7:21pm
Thanks, Ross!!!---it is perfect timing!! ----I did hope that a 20 foot bed would hold it! lol!!!
That's a REALLY NICE lookin D in your pix!! thanks again to all!! ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 12:49pm
Hi.   I noticed that you might have mismatched rear tires for size and tread pattern. A 'D grader' friend, had to replace his 'drives' because all four tires/wheels must travel the same. It is a hard/expensive repair if you have to get into the drive sprockets, chains, etc..
I hope you don't mind me mentioning this. Parts are getting hard to find. I am currently working on trying to replace/find some hydraulic brake parts, and the emergency brake components. My 'D Special' is a 1967 model, so it has hyd. brakes.
   On a lighter note, did you and Shameless notice that the tape measure I used, for the grader length measurement, was somewhat odd, 18.10 = 19 ft. This measurement is odd, no doubt. Canada has been Metric for a lot of decades; but, this is sure different. One side of the tape has feet/inches, and the other side has this odd combination.
   Ross.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 3:33pm
Ross, I have to disagree about the tape measure. It still measures in imperial but is actually an engineers tape that measures in feet and 1/10 of a foot instead of feet and inches. As an engineer I have both plus metric tape measure and a calculator that can help with conversions. I also agree that all the drive tires must be identical to help preserve the final drive system and wear and tear on the tires since all four wheels are locked together and there is no differential. It is somewhat similar situation with a dual wheeled truck. If you only buy two new tires, don't put one on each side but put the two new tires together on one side and the two worn tires together where the differential can adjust for the difference in outside radius.
This page was generated in 0.367 seconds.
