EMUSA turbo?
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Topic: EMUSA turbo?
    Posted: 15 Oct 2018 at 9:01pm
I think the turbo is going out on my 96 Freightliner with a Cat 3126 engine.  Squeaks like a bearing is going.  Limped it home in a snow storm a couple days ago.  Took the serpentine belt off to make sure the alternator, AC compressor and idler bearings were OK.  Needs a new belt but when I started with the belt off I still heard the squeak.  I was looking online and find a EMUSA turbo, brand new, for $350.  Anyone have any experience with them.  BTW I only drive the truck a few thousand miles a year.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2018 at 9:39pm
$350. sounds pretty cheap!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2018 at 9:42pm
Yea, and you know more then anyone how cheap we are!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2018 at 9:45pm
yep! yer lucky, everything I only use about 1-2 times a year usually costs me about a grand to get them going!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2018 at 3:11pm
$350.00 sounds chesp compared to if it comes apart and goes threw the engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 12:07am
I agree tadams, I got the turbo off the truck and nearly apart.  Am thinking I'll see if I can just buy the innards - bearings, shaft and seals.  Cost less then a couple hundred bucks and might even be US made.  The turbo is Cat brand, suspect they buy it from someone else with their name on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 4:55am
Turbos do not have 'Bearings' as such most have floating bushings, float In the housing and on the shaft so they ride in a oil bath to reduce friction. If squeaking probably has had a bushing or lube feed failure and allowed the blades to contact the housing or a housing has come loose and shifted or warped on the exhaust side. Better off to get a reman or a replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 11:47am
I took the turbo apart and see what you are talking about D miller.  The shaft seemed a bit loose but I noticed some build up of what, for lack of a better word, calcium on the intake part of the turbo, which is made out of aluminum.  I can't see where the blades touched the housing but may have just barely touched them.  Thinking of buying a new or rebuilt cartridge as the rest of the unit is in good shape.  The engine has good oil pressure and everything seemed to be well lubed in the shaft area.
