170 gas thermostat
orangeonly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeonly Quote  Post ReplyReply Direct Link To This Post Topic: 170 gas thermostat
    Posted: 12 Oct 2018 at 12:38pm
Been calling around can't find one for gas they all say they have number for diesel. Anyone know part number or one that interchanges ?
Thanks
If it ain't orange it ain't worth ownin'
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 2:08pm
Below is the list from the AGCO parts book:
http://www.agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/79001560
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 3:12pm
Been calling around to someone other than an AGCO Dealership ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 6:29pm
Last one for a diesel I got from AGCO was wrong, ordered another from Sandy Lake, it was wrong also. Went to Napa, went thru a bunch before I found the correct one. Can't find the part number now. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeonly Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2018 at 4:36am
Thank you for the replies. I went to napa first said they couldn't get it for gas, but could deisel.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2018 at 6:22am
It's the same one for all D17 gas and even for the old WD45 gas tractors. Call Tony at (503)767-3660 he will fix you right up, just say it's for a D17 gas.
Bruce Nelson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce Nelson Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2018 at 9:25am
I just put a NAPA thermostat in a WD-45. Part number 280. Might be the same for 170.
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2018 at 6:51am
https://www.rockauto.com/en/catalog/international,1977,scout+ii,5.0l+304cid+v8,1175138,cooling+system,thermostat,2200
Click on above. It's a larger diameter then used in a typical '70's General Motors vehicle.
Thermostat for 1977 International Scout II V8 is the same. I use a 180 degree.
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2018 at 2:05pm
I agree with Phil.  With most of these tractors doing light work, a 180 degree or even 190 keep them  burning clean.  A lot of these tractors came from the factory with 160 degree thermostats which were great when we worked them hard on tillage day after day, but for the occasional use, and light duty 160 is a bit too low.  Had problems with plugs fouling and hard starting until I switched to the higher temp thermostats.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2018 at 2:27pm
A hotter engine is more efficient. Today's oils can tolerate these warmer engines too. As long as you're not boiling the water you should be okay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2018 at 12:46pm
This page was generated in 0.605 seconds.
