11.2-24 tires/8in rims
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Topic: 11.2-24 tires/8in rims
    Posted: 12 Oct 2018 at 12:30pm
I found a matching set of used tires, 11.2-24. I was thinking about getting them for the B. It only has 8in rims. I think they will probably go on, but it might not be a good idea. Will it be ok?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 8:05pm
I'm sure it's been done before. Go for it. How many WD's had wider tires stuck on a 10 inch rim?? THOUSANDS of them.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 8:38pm
The beads are narrower than the maximum width of the modern tire which is the width specification. Go hunting for an Ag tire handbook and it will have a chart of approved rims for tractor tires.
Gerald J.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2018 at 10:39am
 When I was a kid almost every WD had to wide a tire on the stock rims. the only ones that showed was the tractors that saw a lot of road miles. they would wear out in the center since the tread didn't lay flat like it should.  Id put them on and run them. they will fit just the tread wont lay flat. your not gonna be doing and high speed driving with a B. I had 11.2s on my C for 32 years without a problem. it had 9" rims.
