Any Ford 7.3 Techs Here?
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: Any Ford 7.3 Techs Here?
    Posted: 10 Oct 2018 at 11:22pm
I'm having a repeat issue which three diesel techs have not been able resolve. A bad oil leak from the pedestal base. It will pump out 2-3gals in 20 miles. O-rings replaced as well as a new pedestal. Any help please!
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2018 at 12:40am
Need a boat anchor?👻. Who nees a V8 anyway? There are straight 6s out therethat run forever👍
Les Royer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2018 at 1:30am
I'd say either your new orings slipped out of place or the oil is coming from somewhere else.
I still gots my A/C but it's clear out in the barn now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2018 at 1:54am
I assume you already know that there are orings between the pedestal and the turbo.  There are also plugs on the back of each head with orings that can leak. And there is a metal tube on the right head, intake side that sits in a metal holding bracket , with the tube going to the rear of the cylinder head. That tube can get a hole worn in it from that holding bracket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2018 at 9:20am
Pumping out a large amount of oil, it's probably coming from the high pressure pump. There is a kit that has new o rings and fittings for the high pressure lines. Usually what happens is one of the block off plugs on the HP pump backs out a bit and then the o ring fails. Anything that leaks in the valley runs to the back and can look like it's the pedestal leaking. While you have it apart, look at the fuel tubes to and from the fuel filter housing. The right hand line to the RH head can wear on the bracket to one of the intake bolts. I've seen them wear through and make a big fuel leak. There's also a kit to replace all of those fuel line seals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2018 at 10:45am
Every time the pedestal o-rings are replaced the oil leak stops for a time. Some times 2 months some times 2 days. Just don’t know why.
Thanks & God Bless
Dennis
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2018 at 12:47pm
Full disclosure, I don't know diddly crap about the specifics of your issue.
Just a "general knowledge" thought though here, I wonder if the threads are good where you're bolting stuff together?
Edited by Tbone95 - 11 Oct 2018 at 12:47pm
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2018 at 3:05pm
I know it might be a stupid question. Are they using the right kind of o-ring?
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2018 at 10:09pm
I agree with Farmboy and will add are they torquing the pedestal bolts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 6:48am
Torqueing and rechecking after a warm up cool down cycle.....kinda part of what I was askin' too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 8:04am
Are you replacing the pedestal with one that still uses the exhaust back pressure valve? Cause, you guessed it, there are orings there too. Visit Riff Raff deisel. They got a pedestal that deletes the back pressure valve in it's entirety.
Hey, it's one less leak to have to worry about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2018 at 8:36am
riff raff???? lol, another good name for a ferd!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2018 at 8:38am
There is a valley pan on the 7.3 diesel that CAN and many DO leak, there is a PCV system grommet in that pan that also age hardens has that been looked at? It is retained by the intake and ONE Allen head plug style fastener, they DO come loose.
Edited by DMiller - 13 Oct 2018 at 8:40am
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2018 at 9:58am
having done many 7.3 fords i would go with what brian jasper says will probley have to remove the pump to get to the last oring that needs replacing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2018 at 12:35pm
There is no valley pan on any 7.3 Powerstroke, never has been. I haven't seen an indirect engine for many years now so I can't really say about them. Aside from the HP oil pump and turbo pedestal, the only other possible place oil could leak in the valley would be the lift/transfer pump used from 94 to about 96. Afterwards they used an electric pump and the hole for the lift pump is closed off with a cup plug. There is also no PCV system in the valley either. There is an oil separator on the left side valve cover only.
Heavy truck applications might be different, but the pickup engine isn't built that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 4:10pm
Sorry it’s been so long. I forgot to inform everyone what was found. The pedestal “O” s were leaking again. This time they replaced the pedestal as well. It hasn’t leaked a drop since.
Thanks & God Bless
Dennis
This page was generated in 0.438 seconds.
