Headlights on HD16
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: Headlights on HD16
    Posted: 08 Oct 2018 at 10:56am
Question for you cosmetic experts.
My early model 1961 HD16 had lights behind the upper grip. Standard I know.
On my hood almost directly over that area are also 2 threaded holes on each side of hood.
Did they also have an option for outside top mount headlights as well. I believe one of Ricks tractors has lights externally mounted. Curious.
HD16DC, Bobcat 863 Turbo, Oliver 1855, John Deere 855,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 3:13pm
Not sure I can be of any value but over in the red world I see tracked units set up with lights on top and or sides depending the application. Farm units had them on the sides and construction units were generally on the top with guarding.
 Regards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 3:15pm
Thank you Chris.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 3:28pm
Jerbob,
Your welcome. Mel would be one of the guys that will have way better info than I do.
I just own a tracked tractor, off color, I am still learning about them too.
