720 sickle mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 720 sickle mower
    Posted: 05 Oct 2018 at 8:56pm
I was lucky enough to buy a slightly used sickle mower 2 years ago from a nice fella from Iowa. When it arrived it was missing the right side lift cable. He was not able to find it. I was told they were no longer made. Luckily I had a parts tractor that had lift cables, I removed the 2 end clevises. Bought the correct size cable and some crimps at a poultry specialty store. Problem is, the factory crimp is a square crimp about an inch long. The crimps I have are only maybe 5/16” wide. So I put 2 crimps back to back. I have the proper crimp tool but after using it for 2years now it has pulled out of the crimps several times. I do use the mower quite often. My question is, has anyone been able to buy the factory cables and if so from whom?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2018 at 6:24pm
Any suggestions??
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2018 at 10:20am
You could attach a pair of adjustable hanger rods or eye bolts to the mower frame directly below the standard lift cables on each side, then you continue using the mower deck lift cables.
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
This page was generated in 0.467 seconds.
