Harbor Freight Saw Blade
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Topic: Harbor Freight Saw Blade
    Posted: 05 Oct 2018 at 9:42am
I bought a 7 1/4" carbide metal cutting blade for my Skil Saw from Harbor Freight. Used it for the first time today on some channel steel 3/16 thick. Cut through it like a hot knife through butter! No grinding ,hot sparks flying, just like cutting a 2x4 ! Every once in awhile Harbor Freight has a good product !
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2018 at 4:33pm
I will have to look into that.. didn't know they had such a thing for skill saws.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2018 at 6:08pm
what was the name on the blade?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2018 at 6:24pm
better go back and buy  the whole batch of them ! especially if they're on sale. Local store here had 'ultra thin' 4.5 cutoff wheels at a great price(75%) so I bought 1 pkg of 10. Sure wish I'd tried them as they were great but by the time I got back to store , they were sold out. Next sale,same item, LOUSY..yeah I bought 4 pkgs of them..arrgh...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2018 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2018 at 10:50pm
Yep Steve found the blade! I might have to buy some more!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2018 at 12:28am
Do not use those if your saw has a plastic case. Years ago, many years younger I did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2018 at 1:26am
I need blades to cut tin roofing. and my Dewalt has a plastic case....why Tom?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2018 at 6:08am
cause the white HOT metal  cuttings WILL melt the plastic guard around the saw blade.
You'll figger that out when a long stream sparks come shooting THROUGH the plastic..
yeah BTDT....
NOW I have a metal saw for cutting metal...
..though my $400 MG saw went 'walking' ( probably into the 'contractors' trailer)..
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2018 at 7:56am
My Skil Saw has a plastic case around the motor and metal where the saw is and I have used it with a fiber cut off wheel for years with no problem. Talk about sparks and sl*g! This Harbor Freight blade gave off very little sparks off course it is new and still sharp.
Edited by klinemar - 06 Oct 2018 at 7:56am
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2018 at 8:08am
For metal roofing try putting a regular wood saw blade on backwards, seems to work well.
Dusty
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2018 at 9:16am
Seen the backwards blade trick work. Made one helluva noise, but it worked.
Don’t have first hand knowledge of the HF blade, but I believe MK Morse introduced the Metal Devil blade about 5 years ago. Generated very little heat.
Edited by Tbone95 - 06 Oct 2018 at 9:16am
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2018 at 2:34pm
I always used a plywood blade in backwards for metal roofing
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2018 at 4:37pm
I agree with Tbone about the noise that a backwards blade makes when cutting roof metal. Double or triple ear protection is required. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2018 at 5:04pm
Son has a Milwaukee metal cutting saw - has a pocket on side of guard to catch metal chips -blades  are carbide tipped - one problem is the steel now on the market has carbon pockets and when the blade teeth hit these hard spots they will shear off or chip.
 A low cost blade put in backwards will work for sheet metal or metal roofing but it does leave somewhat rough edge of pushed to hard and fast
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2018 at 5:12pm
klinemar.. you said you cut 3/16 plate... I thought this was a sheetmetal blade ?  I have seen steel saws, but the ran about 1000 rpm, not 3600 ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2018 at 8:27pm
The time I saw the backwards blade work, it was on aluminum plate. I don’t recall the exact thickness, but it was 3/8 to 1/2 inch. The noise was BRUTAL.
The metal devil was cutting 3/16 angle iron on a decent, but plain ol skill saw. It was awesome.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2018 at 8:36pm
I needed to cut a new metal bath partition once.  Parts runner got me a Lenox branded, toothed blade from Lowes-I said somethings I regret about his competence, but put it on my worm drive Skilsaw anyway.  I was cutting 4" off, so had some area to 'play' with.  I HIGHLY recommend that blade to anyone.  SMOOTH and fast!  I realize partitions are 2 sided sheet metal, but the packaging said it works up to 1/4" steel, if my memory has not failed me!
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2018 at 9:04pm
I hope you appoligised to yer worker! thanks ya'll, i'll try the backwards blade one of these days!
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2018 at 8:25pm
Yep it melts the case. I did it several years ago. Dog gone it. I was at HF today and forgot to pick up one of these blades. Although I am done cutting steel for the year, I gotta add on to the east side next year. Dang good reason to go back next Saturday.   Old gal says I can have that day off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 6:03am
I tried the backwards saw blade and did not like the cut it left in steel roofing or the noise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 7:34am
Had the piece of metal siding on the saw horses and used a backward plywood blade to cut it.  (plywood blades have more teeth, so a little quieter)  So,,,,,,I'm sawing along and all of a sudden it kinda bogged down.  Well, that's usually because I'm standing on the cord,,,,,which I wasn't... so I started in again and it kind of grunted through the next couple inches and then cut real well again.  As it got through the 'bogged down area', I heard a 'clunk' and there laid the tail off of my steel square...AngryAngry  Yep, cut clean through it....
When cutting steel roofing or siding, it's noisy for sure, but it works.  I'd rather use a shear!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 8:59am
I've got a little question about saw blades.
I would like to put a 4-1/2" blade in my side grinder, but can't find one with a 7/8" bore.
Can a saw blade be drilled drilled to a larger bore, or are they too hard to drill ?
Dusty
