Does a M straight cut head fit on a L?
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Topic: Does a M straight cut head fit on a L?
    Posted: 02 Oct 2018 at 9:38am
Looking for a straight cut head for my L3 combine.   Wreckers say they have one from a M. (20 ft)
Does it fit?
I realize 20 ft width is fine.   I'm wondering about the actual hooking up?   Is there any differences?
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 9:43am
Yep, those were called L/M heads, will fit both.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 11:59am
You just have to adjust the hooks on the bottom to match the L feederhouse
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 12:41pm
Thanks for the quick replies!
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 10:11pm
Check the serial number plate. If it just says M, its an early unit with the hooks welded solid for the M hookup, even though the slots are there for the L hook position. Some fabbing will basically convert it to L/M
If it says L/M, it will fit.
If its off a straight L or M and is going on a 2 or 3 series, you will need to notch the upright for feeder beater drive clearance.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2018 at 12:01am
The header is about 3+ hours away so I asked for some pics. This was before I read your post Gm Guy. I could phone again to verify that it is a straight M. But we're supposed to get snow...and might not combine at all if the weather doesn't improve. So the swather is going out!
I've noticed it has mechanical drive for the reel.   And my L3 has variable hydraulic drive.   I'm guessing this is a straight M?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2018 at 1:27am
Definitely off an M with the Flighting extensions and the stripper plate extensions.
Cannot tell if its straight m or L/M without seeing SN plate.
Drivelines are correct.
Not a 2 or 3 series, definitely a first generation, so the upright will need trimmed. way less trimming on a L2/3 application than M2/3.
Overall looks like a decent enough head.
If you have a grain spec machine, you may be missing the variable speed valve in the stack that was used for this style reel, as well as the variable speed feederhouse on the corn/soybean spec machines. I have a L3 this way.
