throttle linkage/steering rod fix
Jeff(WC)(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Topic: throttle linkage/steering rod fix
    Posted: 19 Jul 2010 at 8:37pm
I have a lot of slip in the ends of the throttle linkages on both my wc and wd45...how do you guys fix these?  weld em up and grind em down and drill new holes?
also on the wd45 it has a LOT of slop where the steering shaft goes into the u-joint...if the wear is on the actual shaft how do you fix this short of finding another shaft, since mine has been cut and a char-lynn PS unit has been added to it....but since i have the PS i can;t feel the slop so the tractor does the wanders down the road
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2010 at 9:42pm
drill it linkage larger and put a bushing in it. JB weld or Bellzona the shaft
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
