D19 Propane
190XTLP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190XTLP Quote  Post ReplyReply Direct Link To This Post Topic: D19 Propane
    Posted: 01 Oct 2018 at 7:35pm
Got a D19 that tubs n idles perfect till warm then will die at idle unless choke is pulled out quickly. Original Ensign system n regarding was rebuild with no difference
WD45G,WD45D.190XTD,190XTLP
D19LP,WC unstyled,WF unstyled
WC styled,220
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 10:31pm
"tubs"?  Maybe water in the system that heats up and plugs the carb?
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190XTLP Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 7:07am
Replaced filter...no water or dirt in it
Just won't idle when warm
WC styled,220
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 8:11am
Possible intake leak that changes with temperature? I had a inline 6 engine in a pickup that had symptoms as you describe. It had a crack in the intake manifold that would open up when it got hot. Cold it ran fine. Get it warmed up and spray some carb cleaner around on your intake manifold and also where it meets the head.
Ben
