8050 Transmission Oil |
Johnwilson_osf
Joined: 29 Jul 2012 Location: Mount Bethel PA Points: 944 |
Topic: 8050 Transmission OilPosted: 01 Oct 2018 at 11:22am |
All,
I am trying to chase some missing hydraulic Fluid. We were chopping corn the other day, and at lunch we checked the oil levels in the tractor. The Transmission was showing at the Add mark for 2WD, which is low for 4WD (this is a 4WD PD tractor). We topped the transmission off, and continued on the rest of the day. Checked it that night, and it was in the 4WD zone. A day later, we look again, and the level is down into the 2WD marks on the stick. I am loosing Oil, but I cannot figure out to where. There is no puddle on the ground under the tractor. If there was a dipstick in the rear end, would I see it rising? Are there other places for the Transmission to leak into that I would not be able to see? Thank you, John |
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2 |
hillmonkey
Joined: 03 Apr 2010 Location: oville fl Points: 417 |
Posted: 01 Oct 2018 at 12:00pm |
CK all of your other fluids,one of them will be high. That is where its going.
DrAllis
Posted: 01 Oct 2018 at 12:36pm |
If the oil is truly disappearing from the dipstick to the transmission, it is either going into the rear end (sight glasses) or on the ground. It isn't evaporating. Checking oil level first thing in the morning with the tractor sitting LEVEL is the best way to check.
Johnwilson_osf
Posted: 01 Oct 2018 at 4:21pm |
Thank you. When I check the tractor next, I will build a dipstick for the rear end to see if I can watch the level rise.
I will make sure that the tranny stays full, but is there any problems with having an overfull rear end? Also what sort of repair would be needed to stop this leak, if it is into the rear end? |
MACK
Posted: 01 Oct 2018 at 10:24pm |
Save your time building a dip stick for rear end. There is a splash plate below fill hole that will keep you from putting a dip stick in.
Screw top sight glass out for oil level. Most likely place for transfer is in gear pump and pump drive shaft seal behind pump. MACK |
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 02 Oct 2018 at 12:48pm |
so when they transfer oil due to internal leakage at pump seal, it goes from trans to rear end? Not rear end to trans? Been keeping an eye on the oil levels on the new to me 7040.
Big Orange
Posted: 02 Oct 2018 at 1:38pm |
The seal just in back of the georoder pump is probably bad, and pumping oil to rear housing.
Johnwilson_osf
Posted: 14 Jan 2025 at 3:14pm |
Greetings Allis Family,
The tractor is leaking again. When this originally happened (2018), I replaced all the seals in the Gerotor pump. Put the pump back in, and had no problems until this week. I am loosing fluid from the transmission to the rear end again. Let's assume that when I rebuilt the pump, it was done perfectly. I see either two options. Option 1: The seals failed and I need to do it again. Option 2: There is another location for the leak. Is there any way to identify where the leak is happening? Is there a way for me to plumb the rear end into the transmission to refill the lost oil? I already have one tractor split, getting a new engine and clutch, so I am not ready to do this one. Thank you John
DrAllis
Posted: 14 Jan 2025 at 5:19pm |
A non-AGCO set of hydraulic filters under the belly can cause high suction at the gear pump placing that shaft seal under more stress. I'd go for the same shaft seal at the gerotor pump being the culprit (again). When installing that seal, I always wrapped the splines on the shaft in barber pole fashion with one layer of electrical tape. Oil with WD40 and slide the seal over the splines without damage to the seal during installation. I have a friend who fought a 7020 tractor for this and he finally installed that gerotor seal BACKWARDS and claims that solved his problem. By installing the seal with the spring to the rear really helps keep the steering pump from sucking transmission oil thru it.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90800 |
Posted: 14 Jan 2025 at 7:16pm |
Dr...... is there a problem connecting the two DRAINS with a hose ? What would be the "level" ?
Johnwilson_osf
Posted: 18 Jan 2025 at 3:58pm |
Dr. Allis,
Thank you for the help. I will likely pull the pump out and replace the pump in a few weeks, when the temp warms up. I don't have a heated shop, and it is supposed to be real cold the next week. John
