185 pto
wlambs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wlambs Quote  Post ReplyReply Direct Link To This Post Topic: 185 pto
    Posted: 28 Sep 2018 at 5:47am
have a 185 that i can run a roller pump on pto and it stays engaged but if i put bat wing,hay conditioner or feed mill on pto will not stay engaged.any ideas on what all will have to be done to fix.seem to have play in shaft,can push in more than should
wes
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 8:28am
Linkage worn out not letting it to go all the way in. Then shaft gets worn tempered on end.     MACK
