D 19 diesel
Mike K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Topic: D 19 diesel
    Posted: 27 Sep 2018 at 12:17am
I am looking at a D 19 diesel. The block head bolts holes are warn. The person put a helocoil in a couple.New head gasket. What do I need to watch out for. Cracked head maybe.
 Thanks for the help   Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 7:00am
Run away. Don't walk...RUN.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 7:35am
Cracked heads, sleeves recessed into the block = $$$$$$. Buy it cheap and plan on a complete overhaul ($5K to start), or take the Dr's advice....
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 9:31am
or buy it cheap and put in a 433 I... or a cummins 4BT
 ...or... put in a 6 cyl. gas.
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 6:46pm
Or just keep that money and invest it into a tractor that doesn't need expensive repairs from the get-go.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 8:29pm
After our farm owned a '19 gasser for 5 years, look for/at ANYTHING else. JMO.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 8:09am
Had to chuckle a little reading this post, this must have been ours from 40years ago, father said it needed zippers--lol. Took two people for grinding feed, one to load corn and another watching the tractor for leaks. IMO-- the D19 diesel is a liability, not an asset.
1852 Moore Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1852 Moore Farm Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 8:39am
From personal experience with a 19 gas...it seems to be a one sided working relationship.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 9:37am
Look out for this along with the treads pulled, dropped sleeves.
