CA Oils
1955CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Topic: CA Oils
    Posted: 22 Sep 2018 at 10:21pm
So got stage one done today. Picked up my operators, service and parts manuals for my newly acquired 1955 CA.
I see it says that the hydraulic system and final drives call for SAE 20 motor oil?
I would have thought it had hydraulic oil.
As far as the engine I am going to use Petro Canada Duron HP 15W40. When I looked at the data sheets I see it has higher zinc levels than Rotella.
My tractor also already had a WIX engine oil filter on it, so I just got another one of those, but the number has been superseded to 57011.
Am I on the right track or do you have any other suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2018 at 10:26pm
Transmission/hydraulic system and final drives will use todays Universal Trans/Hydraulic fluid. No manufacturer went out and re-printed the 1950's Owners Manuals to reflect modern day lubricants. 20W non-detergent oil was best in 1955. Universal Trans/hyd oil is best today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2018 at 10:36pm
So my final drives and hydraulics call for 20W above 45*F and 10W below that.
Now mind you these manuals are from 1955.
Petro Canada only makes a 10W and a Duron 30 Monograde. The 10W says
it works for hydraulics, and Cat and Allison transmissions.
The 30 does not specify this.
Do you think the 10W will be okay or should I look for a 20W from someone else?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2018 at 10:42pm
So Dr.Allis......so would this be any good? Or better to use than the monograde oil?
What about the Kubota Premium UDT I have for my Kubota?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2018 at 11:17pm
John Deere HyGard or Case IH HyTran  or AGCO 821 XL or AGCO PermaTran or their equivalent.
Edited by DrAllis - 22 Sep 2018 at 11:18pm
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 6:32am
When I opened their website and clicked on "OEM APPROVAL", it brought up a list of manufacturers fluids that it is compatible with. AC Power Fluid 821 was compatible, so the answer is yes, it is what DrAllis was talking about.
From prior threads on this forum, the experts are saying you can use it everywhere on the old AC tractors, except the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 6:37am
gee I used straight SAE30 for the engine and 'WallyWorld UTF (yellow rim ?)' oil for everything else in my CA as well as 4 D-14s......
sure makes it easy to member what goes where....and everyone was/is happy...
btw what part of ontario, I'm near Hamilton.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 10:41am
OK thank's guys. I'm north of Sault Ste. Marie Jay.
I just wasn't sure, with it being an old wore machine if it was better to go back to the thicker monograde engine oils.
And I always have pails of Kubota UDT here, so that's why I was wondering if that was compatible also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 12:54pm
Kubota UDT is an approved oil.
OEM Approvals
Case New Holland
  • MAT3540, MS-1209/MAT 3505, MS-1210/JIC-145/MAT 3506, MS-1230/CNH MAT 3509, ESN-M2C134-D/MAT 3525, MS-1207, MS-1206, MS-1205, MS-1204/JIC-185, B-6, B-5, JIC-144, JIC-143, FNHA-2-C-201.00, ESN-M2C134-A/B/C, ESN-M2C86-B/C, ESN-M2C53-A, ESN-M2C48-B – Suitable for Use
John Deere
  • JD J20C – Suitable for Use
White Farm (Oliver)
  • Q-1826, Hydraulic Transmission Fluid (HTF), Q-1802, Q-1766B, Q-1722, Q-1705 – Suitable for Use
Massey-Ferguson
  • M-1141, M-1135, M-1143, M-1145*, M-1129-A, M-1127-A/B, M-1110 – Suitable for Use
(*Note: For UTTO applications only. Do not use in STOU applications.)
AgCo / Deutz-Allis / Allis
  • Power Fluid 821XL, 272843, 257541, 246634 – Suitable for Use
ZF
  • ZF TE-ML 03, 03E, 05F, 6K, 06K, 21F – Suitable for Use
Kubota
  • UDT - Suitable for Use
Steiger
  • SEMS 17001 - Suitable for Use
Versatile
  • ESN-M2C134-D - Suitable for Use
Landini
  • Tractor II Hydraulic Fluid - Suitable for Use
Hesston-Fiat
  • Oliofiat Tutela Multi-F - Suitable for Use
Volvo
  • WB101 – Suitable for Use
API
  • API GL-4 (Manual Transmissions, Spiral Bevel Axles, and Hypoid gears inmoderate service) – Suitable for Use
Allison
  • Type C-4 and C3 – Suitable for Use
Caterpillar
  • TO-2 – Suitable for Use
Sundstrand
  • Hydrostatic Transmission Fluid – Suitable for Use
Plessey - Sundstrand
  • Suitable for Use
Dresser Construction Equipment Division
  • Transmission/Hydraulic Fluid – Suitable for Use
Clark Lift Truck Transmission Fluid
  • TA12, TA18, HR 600 – Suitable for Use
Parker / Abex / Denison
  • HF 0/1/2 - Suitable for Use
Eaton / Vickers
  • M-2950-S, 1-286-S – Suitable for Use
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 1:07pm
Thank you all. Maybe I will just use my Kubota UDT then. That way there everything I have will be the same and I always stock it here.
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 8:05am
<h3>OEM Approvals</h3>
Case New Holland
John Deere
White Farm (Oliver)
Massey-Ferguson
ZF
Kubota
Steiger
Versatile
Landini
Hesston-Fiat
Volvo
API
Allison
Caterpillar
Sundstrand
  • Suitable for Use
Eaton / Vickers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 8:06am
I know this is 2 years old but thanks for the info, Matt 👍
This page was generated in 0.097 seconds.
