WD Steering shaft |
Post Reply ![]() |
Matt Tallant ![]() Orange Level ![]() Joined: 15 Aug 2011 Location: Virginia Points: 691 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Sep 2018 at 7:15pm |
Is anyone reproducing them?From Wheel to u joint Thanks,Matt
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22085 |
I make my own. Just a piece of cold rolled steel (not hot rolled) cut to length and drill two 3/8" holes.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8543 |
7/8 diameter if I remember right. I try to salvage mine, mainly because I am cheap. But getting the steering wheel off can take its toll.
Not sure what the demand might be if you were to reproduce them? Couple a year maybe??? Just a guess? Regards, Chris
Edited by Sugarmaker - 21 Sep 2018 at 7:54pm |
Very low demand and the shipping cost for something that size ??????????
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
Easy to have a local shop make. I had to have one made for my WC. AaronSEIA
Ross D. ![]() Silver Level ![]() ![]() Joined: 02 Sep 2013 Location: Erin, Ont. Points: 339 |
Good morning. I turned mine around and drilled two new holes. I also added grease nipples and bronze bushings where required. Ross.
There's nothing that takes away from a nice fresh paint job than a worn and rust pitted steering shaft that is now bright and shiny.
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
While you have the shaft out, I'd suggest replacing the tension springs behind the throttle quadrant for the levers. Also be sure to replace the shaft bushing in the quadrant and drill out the lower support by the engine for a bushing or you will still have slop with a new shaft. The old shaft makes a good pry bar or cut it into sections and you have a nice big punch set.
Post Reply ![]() |
