6080 injector replacement now won’t start?
rudyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Topic: 6080 injector replacement now won’t start?
    Posted: 19 Sep 2018 at 8:00pm
I Had the injectors rebuilt on 6080, now won’t start.
I cracked the lines to injectors and had fuel running out, tightened them back up and still nothing.
While it’s turning over I am getting some exhaust. Any tricks or suggestions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2018 at 8:14pm
Couple of unknowns, did you just pull the injectors to have rebuilt or did you also replace the fuel filter? Pump may need to be bled also. Bleeding them works best if you have someone in the operator seat turning it over as you operate the wrench. I always have the injector nut tightened on each injector and bleed each line one at a time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2018 at 8:26pm
I had the pump rebuilt by injection pump ed a couple months ago, he did a great job.
I will try bleeding the pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2018 at 10:14pm
Do the lines from pump go in top or side of injectors? I would loosen all 4 lines at injectors and crank until all run clear fuel, then retighten.    MACK
troym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troym Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2018 at 7:19am
While it is rare i have seen where when bumping up the pressure on the injector when rebuilt. may cause it to be to high for the pump to open the needle, ask the guy who rebuilt them if he raised the opening pressure that will help troubleshoot, it could be that your injection pump cant quite open the needle do to age of pump. just my experience.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2018 at 7:41am
My guess is the guy set them so high, it won't pop them now. Not sure who did these for you, but it sounds like a bad deal all around. This tractor has AC injectors in it. It's the first time I've seen a 6080 with AC injectors. I have always seen American Bosch, or Robert Bosch injectors in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2018 at 7:51am
The oldest 6060/6080's never had A-C injectors in them. Always one of the Bosch Brothers injectors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2018 at 8:18am
So someone has swapped engine in this tractor, or something. He texted me a pic of it, and lines look factory, but indeed come in the side, and return is on the top. It had a correct 6080 pump though, DB2437-3837.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2018 at 10:44am
the plot thickens....got an early combine engine? I think my 78 F2 had AC injectors but I'd have to look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2018 at 11:10am
F2 shows AC injectors for early ones.
