Air compressor issue |
Ryan Renko
Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2349 |
Topic: Air compressor issuePosted: 12 Sep 2018 at 8:21pm |
I have a 60 gallon Ingersoll Rand SS-5 compressor that is about 8 years old. Very little use and well maintained. Every thing was great until the last week. It runs as it always did until it reaches around 100psi in the tank and then it falls on its face and the motor bogs down and the belt even starts slipping!! If the breaker doesn't trip after about 10 seconds of this belt squealing it will pick right back up u til it shuts off. Any ideas on this? Thanks in advance, Ryan
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25269 |
Posted: 12 Sep 2018 at 8:34pm |
Have you drained the water from the tank recently ? Have you replaced the belt and adjusted for proper tension ? Any slipped belt will become 'glazed', so not as 'grippy' as it's supposed to be so when the motor sees extra load( 100 PSI), it'll 'stall' out. Not the right 'engineering' terms but...hopefully you get the drift.. Jay
Ryan Renko
Posted: 12 Sep 2018 at 8:40pm |
I relocated the factory drain valve so it is out front and it is drained after every use. The belt seems as tight as it should be. This issue just rapidly started happening and I am needing advice before I call the company. Ryan
Edited by Ryan Renko - 12 Sep 2018 at 8:41pm |
farmboy520
Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
Posted: 13 Sep 2018 at 12:06am |
I wonder if the check valve that is after the compressor and before the tank is operating correctly?
shameless dude
Posted: 13 Sep 2018 at 3:23am |
try adjusting the PSI down a little bit
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8479 |
Posted: 13 Sep 2018 at 10:02am |
Grandpa has an air compressor from the '50s and it has this problem sometimes.
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 13 Sep 2018 at 10:11am |
Well,,I started havin the same issue with my compressor couple weeks ago and I figured it was the motor as it is very old,,,,but since that time it has been runnin just like old times,,,,WHH,,,,???
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 13 Sep 2018 at 3:44pm |
I agree with the check valve issue, it is getting some back pressure above 100 psi and the pump is trying to push against a closed/part closed valve. Could be a broken or corroded spring that all of a sudden let go, I imagine that would be an fairly cheap part.
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 13 Sep 2018 at 4:28pm |
Aunt Peg would say they are sending cheap electricity and charging premium price.
