1001 running gear
Fat farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fat farmer Quote  Post ReplyReply Direct Link To This Post Topic: 1001 running gear
    Posted: 11 Sep 2018 at 6:28pm
Sorry can’t seem to find info. I have a 1001 running gear but not sure of rating. Was told 12ton but no clue. Thanks in advance on any help.
mintenfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2018 at 6:37pm
Model 1001 is the big, rugged gear built to carry 10 tons and handle a high-lift hoist, this is directly from an old advertisement I have
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fat farmer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2018 at 6:40pm
Awesome thank you. Seems like a heavy duty gear I may weld a rack on it to bring large bales out of the field.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2018 at 6:47pm
1001 has 8 bolt hubs. Does your have 8"x20" wheels?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fat farmer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2018 at 6:57pm
Not original wheels. Currently has 8ply 11-16 flotation tires. Cat #is 2051547 and I guess model # is rusty but I believe it says 10100
Any idea of year? It really is a beast of a running gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2018 at 10:07pm
It's 10100 on ID tag is it's serial number which is usually labelled as 10 100. The 10 stand for ten ton & I'm going to guess that it's the 100th built?
I think its Year built depends on its decal colors. Older gears (late 50s-1964?) usually have rear frame decal consisting of dark blue letters with orange outlines & no background color(just Allis-Chalmers letters in Blue). I'm thinking these were built during the later Diamond AC logo era.
Newer gears built during the AC square logo era (1965-up) have rear frame decals consisting of black letters (Allis-Chalmers) printed over a whites rectangular background.
If you have photos, please share.
Edited by AC7060IL - 11 Sep 2018 at 10:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2019 at 4:33am
If your wagon’s ID tag says it’s a cat no. 2051547, then you’ve got a later model 1010, not an earlier model 1001. Or at least it’s rear axle frame is a 1010.
A 1010’s front steer axle frame has a forward tie-rod design. It’s tie-rod is placed forward, not behind, it’s front axle frame. The 1000 & 1001 models tie-rods are both located under & behind their front axle frame.
Hard to put a year on it. Best I’ve gleamed is that the 1010 models were manufactured in the early-mid 1970s era.
Edited by AC7060IL - 02 Feb 2019 at 4:38am
This page was generated in 0.093 seconds.
