125 Engine Timing Cover Gasket
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: 125 Engine Timing Cover Gasket
    Posted: 09 Sep 2018 at 1:00pm
Any advice on what to do for a timing cover gasket? Is there a part number for one or do I need to make one? If I make one, how thick of gasket material do I need? This  is for the motor in my CA. I have the part number for the oil seal and speedi sleeve, just had a question about the gasket. Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2018 at 1:03pm
Any AGCO dealership can get you one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 7:24am
Before you tighten the bolts for the cover, let the seal center the cover in place. There are no dowels to locate the cover on the engine. A-C had a special tool that lined up the cover to the crank.
