AC 160 Rotary cutter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 160 Rotary cutter
    Posted: 08 Sep 2018 at 7:10pm
I know it probably has been asked before.Can you still buy the blades and bolts for the 160 mower? Is aftermarket available? Thanks Tracy
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 7:20pm
I'm in the same hunt myself. My blades are a bit worn, and I'm pretty sure I'm going to have to hot wrench the nuts off (and broke off the cotter pins, too). When I asked recently, I was told maybe Agco has the castellated nuts and bushings, but they're $$$. But the blades I don't recall an answer on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 8:11pm
Don't know if I posted on this before, but what I did, years ago, was to measure the drop, and the length, and match up as close as possible...  IIRR, the drop is the limiting factor. Again, IIRR, original drop was like 4-1/2", and the closest I could find was 3-1/2"...
You might try agrisupply, they do have a big selection, and I didn't know about them, back then...Wink
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2018 at 4:12pm
Quite a few years ago I bit  the bullet and bought new from AGCO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 9:17am
Where is the serial number on these mowers? Does anyone have a parts manual of one? Thanks Tracy
Travis(NE) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 4:29pm
Don't tell anyone, but...
When I was working on mine I took all the parts to the local John Deere dealer and they were able to match up everything I needed.  There is a bushing in the blade they didn't have, but it matched up very close to a bearing lock collar and I've been using it like that for years now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 5:55pm
The bushing is pretty much the same, in almost all bush hogs 3/4" ID X 1-1/2" OD.  thickness is a little thinner than the blade...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 8:29pm
Travis, how much were the blades? Were the bolts the same? Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2018 at 9:38am
I honestly couldn’t answer that as it’s been probably ten years ago or more since I did that. The JD parts had to of been pretty reasonable if I bought them tho, if that helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2018 at 6:56am
Not sure on the serial number, but the closest parts manual I have seen is the diagrams in the manual.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2018 at 1:40pm
Tracy, send me the dimensions with hole size and blade offset and I'll look at our co-op. Seen a bunch there yesterday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2018 at 2:58pm
 Scott I haven't taken them off yet. Putting on new lift lower lift links and cranks on the 3 point hitch. Going to try to this weekend. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2018 at 9:24pm
No problem, just let me know when you get one off. I seem to visit the co-op quite often. Scott
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2018 at 6:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2018 at 1:21pm
Thanks, I will check them out. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2018 at 3:49pm
Got my parts manual today. I can see what is available now.Kinda neat to see what options they had also. Thanks Tracy
Edited by Tracy Martin TN - 13 Sep 2018 at 3:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2018 at 5:40pm
bump to top, so i can see replies, before it gets to the unaccessible 2nd page...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2018 at 10:31pm
What did you do to the second page!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2018 at 7:12pm
