Difference between D10 & D12?
KerryM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KerryM Quote  Post ReplyReply Direct Link To This Post Topic: Difference between D10 & D12?
    Posted: 08 Sep 2018 at 1:45pm
Without getting too detailed, what is the difference between the D10 and D12? They look pretty similar, size-wise.
1950 C, 1952 CA, 1961 D17 (Dads last tractor)
1944 Farmall B, 1947 Farmall B, Bobcat 610
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 1:52pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 2:41pm
Width basically D10 is a 1 row tractor,D12 is a 2 row.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2018 at 7:51am
Same in the power train. D-10 is narrower than the D-12.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KerryM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2018 at 10:57am
Thanks for the info! I’ve discovered my niche is these small tractors. Someday, a small D series
Edited by KerryM - 09 Sep 2018 at 10:58am
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 7:25am
2
LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 7:47am
YEAH '2'....
reminds me when my old boss asked what's the diference between a 2N3904 and a 2N3906 transistor. Without hesitation I said '2'. he didn't appreciate my answer, so after 30 seconds of silence I rhymed off the various specs of each of them.still wasn't impressed, though his favorite was...
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 7:55am
2
LOL
Nuts! beat me TWO it!
I am still confident of this;
Wait for the Lord;
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 10:35am
My two for viewing purposes
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 10:37am
D10  side view
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 10:47am
query?
was hi/lo optional on both ?
jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote KerryM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 12:28pm
Drooling... Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 12:42pm
Hi/Lo was offered on the Series 3 D10 and D12
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote KerryM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 1:24pm
Charlie, not to hijack my own thread, but do you happen to have a pic of your D17, so I can see what I probably wish mine looked like?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2018 at 6:19am
My 17, hub ends should be creme, air intake should be silver, other wise I like it.
Charlie
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2018 at 6:50am
Production:
Manufacturer:Allis Chalmers
Factory:West Allis, Wisconsin, USA
Total built:9,100
Original price (USD):$3400 (1967)
Variants:
D10 High Clearance:cultivation tractor
D12:two-row tractor
Allis Chalmers D10 Engines:
   Allis-Chalmers 2.3L 4-cyl gasoline
   Allis-Chalmers 2.4L 4-cyl gasoline
full engine details ...
Capacity:
Fuel:12 gal [45.4 L]
Rear Hitch:
Type:Snap-Couple
3-Point Hitch:
Rear Type:I
Power Take-off (PTO):
Rear PTO:transmission (original), independent (later)
Rear RPM:540
Dimensions & Tires:
Wheelbase:78.75 inches [200 cm]
Weight:2700 to 4800 pounds
Front tire:4.00x15
Rear tire:9x24
full dimensions and tires ...
D10 Serial Numbers:
Location:Serial number stamped into the flange where the engine and transmission meet on the left side of the tractor.
photo of D10 serial number
1959: 1001
1960: 1950
1961: 2801
1962: 4511
1963: 6801
1964: 7675
1965: 9204
1966: 9486
1967: 9795
how to read serial numbers...
Allis Chalmers D10 Power:
Engine:31 hp [23.1 kW]
Drawbar (claimed):26 hp [19.4 kW]
PTO (claimed):30.1 hp [22.4 kW]
Drawbar (tested):28.78 hp [21.5 kW]
PTO (tested):33.46 hp [25.0 kW]
power test details ...
Mechanical:
Chassis:4x2 2WD
Steering:manual
Brakes:differential mechanical shoe
Cab:Open operator station
Hydraulics:
Type:live
Valves:1 or 2
Belt Pulley:
RPM:1220
Speed:2556 ft/min [779.07 meters/min]
Battery:
Number:1
Volts:6
 12 (late)
Page information:
Last update:July 17, 2017
Copyright:Copyright 2017 TractorData LLC
Contact:Peter@TractorData.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2018 at 6:55am
Production:
Original price (USD):$3,522 (1968)
Variants:
D12 High Clearance:cultivation tractor
D10:single-row tractor
Allis Chalmers D12 Engines:
Capacity:
Fuel:12.5 gal [47.3 L]
Rear Hitch:
Type:Snap-Couple
3-Point Hitch:
Rear Type:I
Rear RPM:540
Dimensions & Tires:
Weight:2800 to 5630 pounds
Front tire:5.00x15
Rear tire:10x24
D12 Serial Numbers:
photo of D12 serial number
1959: 1001
1960: 1950
1961: 2801
1962: 3638
1963: 5501
1964: 6012
1965: 9192
1966: 9508
1967: 9830
Allis Chalmers D12 Power:
Drawbar (claimed):25.75 hp [19.2 kW]
PTO (claimed):30 hp [22.4 kW]
Drawbar (tested):29.43 hp [21.9 kW]
PTO (tested):33.32 hp [24.8 kW]
Mechanical:
Chassis:4x2 2WD
Cab:Open operator station.
Hydraulics:
Type:live
Valves:1 or 2
Belt Pulley:
RPM:1220
Battery:
Number:1
Volts:6
Page information:
Post Options Post Options   Thanks (0) Thanks(0)   Quote KerryM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2018 at 9:06pm
Charlie, I like yours too! Yep, I do wish mine looked like that.
And Nella, thanks for the spec sheets. One odd thing, the fuel tanks must be ever so slightly different. One holds 1/2 gal more.
