510 D JD backhoe
wayne3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayne3 Quote  Post ReplyReply Direct Link To This Post Topic: 510 D JD backhoe
    Posted: 18 Jul 2010 at 7:30pm
 I'm trying to take injector pump off. Having difficulty. Seems to be stuck. Any ideas what I'm doing wrong.
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2010 at 8:22pm
which deere motor is in it ??
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayne3 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 7:13am
   German made,4045T Hatz motor. Five Star told me I'd need a puller. Take 2 bolts from front cover, remove drive gear nut, pull gear off injection pump shaft. The ones I've taken off all I had to do was remove 3 nuts,lines,linkage. Then I could change cup seals. This I have to take to repair shop. If there right.
This page was generated in 0.594 seconds.
