D19 yr 1963
T-bone_indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-bone_indy Quote  Post ReplyReply Direct Link To This Post Topic: D19 yr 1963
    Posted: 06 Sep 2018 at 5:19pm
I just purchased a few days ago.Getting the rim repaired now.
so far I have change the
oil and filter
hydraulic filter
added 4 gallons of hyd fluid
greased every fitting i can find
Repair hydraulic leaks and fuel leaks
Loader is functioning now
I have a question when raising the bush hog the arms go down immediately once i release the leaver. is the loader a 500? where can I order pins for it?
I would appreciate any points and suggestions on the operation of this tract and thanks in advance also the owner stated it only has hi gear not sure if there's adjustment that can be done to correct that.
The previous  owner has manuals for the tractor hes trying to locate them.
Edited by T-bone_indy - 06 Sep 2018 at 5:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-bone_indy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2018 at 5:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-bone_indy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2018 at 5:26pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2018 at 8:01pm
That is not a 500 loader.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2018 at 8:02pm
It looks like a Freeman loader to me. You may have to repair the pins you have or make some new ones. Someone on here may know if new pins are available somewhere.
hillmonkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2018 at 8:15pm
I like it, good save.
1852 Moore Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1852 Moore Farm Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2018 at 9:15pm
Nice project.
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2018 at 12:14am
There is a check valve inside the valve for the traction booster that will leak internally which causes the lift arms to not stay up. Usually it can be taken apart, cleaned, and work again when reassembled.
This page was generated in 0.095 seconds.
