Fixing one thing at a time
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: Fixing one thing at a time
    Posted: 05 Sep 2018 at 9:57am
Hello Friends
Cosmetics being done. Section by Section is being sanded and cleaned and primed for final paint. Replaced the Fuel Pressure gauge which was shot. Found a SW unit that fits in the day perfect and works like a champ. Not changing out any other gauges as they work and I think once I start trying to disconnect the copper tubing to the units, could have more trouble than I need right now.
Hood, Battery Boxes, floor plates, air filter assembly all painted and look great. Will be putting back on soon. May not get frame, engine and ROPS cage done this year, as Im running out of time. Not worried as mechanically she runs great and all leaks repaired.
Pics of new gauge and dash in process of cleanup. Also took off the lower front grill to check on the Hydraulic pump and found leaking hose which I replaced. I figure I scraped off about 57 years of acclimated dirt, oil and brush off the unit. Steam washing it and then some paint. Even greased the U joint for he hydraulic pump drive shaft. I doubt that has ever been done. Having a blast with her.
[IMG]uploads/17403/IMG_1344.jpg[/IMG
HD16DC, Bobcat 863 Turbo, Oliver 1855, John Deere 855,
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2018 at 10:11am
Clapshes coming along.  soon you will have to use her
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2018 at 5:50am
Thanks Cal
I've had her out and pushed brush and a little bit of fence row cleanup and she is great to run. Happy to have sorted out all the leaks and most of the electrics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2018 at 7:36am
Looking good! These types of projects can take some time but are well worth the final results. Keep the pictures coming!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2018 at 8:42am
Thank you. I've had her a year now and spend as much time as I can working on her but only have weekends. Spent this first year getting her running good, steering and braking much better, fixed all leaks that I can find, repaired all broken steel like the exhaust manifold, and battery boxes, dumped all oils and coolant, replaced all filters, batteries, many broken wires, bled system and now working on the perfume and makeup. Love every minute I get to spend working on the tractor.
A310 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A310 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2018 at 7:18pm
Looking good, nice to see another Allis being fixed.:)
