Gears
200 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Topic: Gears
    Posted: 03 Sep 2018 at 7:18pm
Has anyone changed gears in a 190 or 200 that is between 7th and 8th gear
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2018 at 8:49pm
Can you change the gears For your power director if your sill running one or manually. Believe it would only be The low side you can speed up and hi would remain the same ratio
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2018 at 1:57am
Power director has been eliminated. Locks only in high or low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2018 at 1:12pm
Then you can change the gears in the housing for faster low side and hi will remain the same
This page was generated in 0.139 seconds.
