looking for a good 816 loader backhoe shuttle |
david a
Topic: looking for a good 816 loader backhoe shuttlePosted: 03 Sep 2018 at 6:59pm |
looking for a good forward revers shuttle for a 816 close to Wisconsin. Also a hydraulic pump for the loader and the steering pump. As long as I working on it would like to fix most of the problems before the snow flys
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42263 |
Posted: 08 Sep 2018 at 10:00pm |
think rebuilding your unit would be the solution to a problem
Check under some of the 715 posts as there is a supplier of parts that might help you find what you need |
david a
Posted: 09 Sep 2018 at 4:02pm |
Thanks is there a good way to get it down and out from under the tractor. Have a transmission jack. but i think the shuttle might be a little heaver than a transmission
Josh H
Joined: 24 Feb 2015 Location: Carnesville, GA Points: 128 |
Posted: 09 Sep 2018 at 8:14pm |
wonder if sumerix implement could lead you on parts
Coke-in-MN
Posted: 10 Sep 2018 at 4:29pm |
They might have access to parts , - its a unit that should come out with transmission jack as the support for it
