Stripped out oil drain bolt |
AlexT
Topic: Stripped out oil drain boltPosted: 02 Sep 2018 at 6:49pm |
Accidentally overtorqued a oil drain plug and pulled out all the threads (aluminum). I dont know whether to use a helicoil or just drill and tap it out for a new bolt next size up. I am thinking I will just re-tap it for the next bigger size but have never used helicoil before and wondered if it might work better. The threads were m12 before I stripped them out.
DougS
Posted: 02 Sep 2018 at 6:58pm |
Once upon a time I saw where someone used a rubber plug after the threads were stripped. It worked. I use a torque wrench when I change my oil. I’m a bit anal in some ways, though.
AlexT
Posted: 02 Sep 2018 at 7:13pm |
yeah, turns out my hand is not as accurate as i thought. last time i dont use a torque wrench.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25255 |
Posted: 02 Sep 2018 at 7:42pm |
hmm... I'd retap to 14mm ,probably size for helicoil..... then find a bolt to fit and a copper washer or just grab a sparkplug ? Ain't them things 14mm ?? be nice, I stubbed my big toe an hour ago, dang thing smarts (unlike me for tripping on carpet in litchen)..... Jay
HD6GTOM
Posted: 02 Sep 2018 at 7:57pm |
You don't need a helicoil or retap. Stop in at your local NAPA store and buy a single oversize thread cutting plug. We used a whole lot of them, when we were in the oil change business, make sure it comes with a new gasket.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55282 |
Posted: 02 Sep 2018 at 8:01pm |
X2, all you need is a wrench, to install...
Mikez
Posted: 03 Sep 2018 at 11:01pm |
Just the other day a guy was in the shop showing us this kit, for the life of me I can't think of the name he called it. He had a Harley and was riding and the drain plug was leaking when the tryd to tighten it was stripped and when he asked the dealer of a fix they said get this kit. So it has a drill bit a tape then it looks like thread insert you turn in by hand then this little tool that when you look at the threads on it they appear to be flat sided and must be tapered because you screw that up in there it expands that insert and sets it in place. It's not a heel a coil. But it definitely looked like it would work great
AlexT
Posted: 12 Sep 2018 at 7:51am |
I ended up using a oversized m12 self tapping plug and it worked great thanks for all the help
