7010 Fuel Tank Cap Leaking
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Topic: 7010 Fuel Tank Cap Leaking
    Posted: 01 Sep 2018 at 7:18am
New to me 7010 is losing fuel  through the cap.  Put a new cap on - no change.  First 7000 series I have had that does NOT have the auxiliary tank.  Is this characteristic of a single tank tractor or do I have something else going on?
Edited by pdh - 01 Sep 2018 at 7:19am
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 7:51am
Check the gasket on the fuel cap. Had the same thing happen on a JD cap. Replaced the original one with a new one and it still leaked. Turned out the gasket on the new one wasn't centered and one edge didn't contact the filler neck. I made a new gasket myself and it has been fine since. Hope this helps. Might check the filler neck for damage too.
