allis sickle mowers
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: allis sickle mowers
    Posted: 31 Aug 2018 at 7:55am
I have a couple sickle mowers (80R and 82T ) ,and on the 82T, all of the wear parts on the cutter bar are pretty well all shot. What do you other allis sickle mower owners use for guards, sections, and hold downs on your mowers, being allis stuff isn't available. .? Thanks, Darrel
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 8:50am
Herschel has all the parts.
I went online and ordered the stuff I wanted.
Actually Tractor Supply Generic wear bars work
The guards are the same as some other brands like Ford
Charlie
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 9:23am
If you don't have many rocks the New Holland double guards will really make the  mower
cut good,used them on a 82S for several years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 10:59am
I like the New Holland double, used them for years. Probably will need one single to fill the spaces up. Tracy
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 1:24pm
I use the New Holland double point guards also, they work great. Also Webb Cutting Components manufactures bolted sickles, they can also get the sickle head if needed. They are great to work with and have been doing it for years. Good Luck, Mike!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 2:06pm
I've bought everything from the local farm stores for all my brands of cutters I've owned thru the years. I just take the old pieces in and match them as close as I can, some are the same, some I've had to modify a bit (grinding down to fit). has always done the job!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 5:56pm
Agrisupply.com, has prolly most of them...Wink
GreenwoodCreations View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenwoodCreations Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 5:59pm
I know its evil: but on my 80R since i was a John Deere Parts Manager, i used the double guards off the deere windrowers with one single deere rockguard and it never complained a bit, cut lots of acres of irrigated alfalfa that way.  (helps to be red/green color blind anyway)
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenwoodCreations Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 6:01pm
question for all:  does anyone know the AC part number or the manufacturers number for the snaller bearing on the twin pitmans?  I have the info on the large one but can't read any numbers on the smaller bearing.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 9:39pm
The small bearing is a fairly unusual style used mostly in aircraft applications.
The A-C # is 804502.
The MRC number for it is KP8.
It may still be available from A-C but I expect it will be a bit "pricey".
I have found the cheapest source is: Aircraft Spruce & Specialty Co. in
Corona, CA.
I bought a couple of them 10 years ago and they were $33.30 each at that time.
Some of the early #7 Twin-Wheel mowers may have used a smaller bearing (KP6).
The larger bearing is quite common: A-C #804501.....Bower/BCA #304DD.
About half the price of the smaller bearing.
This page was generated in 0.508 seconds.
