AD40 Grader |
fishnhuntr
Joined: 29 Aug 2018 Location: Whitehall Mt. Points: 3 |
Topic: AD40 GraderPosted: 30 Aug 2018 at 12:21am |
Just purchased a AD40 grader.Serial number 4070. Diesel 3 speed with hi low box 13:00x24 tires.
Can anyone tell me the year and weight. Was told it was a 1970's by seller. Thanks from Montana way. |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55261 |
Posted: 30 Aug 2018 at 4:50am |
23k lbs, and most likely 1957.
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Posted: 30 Aug 2018 at 5:08am |
DIY Dave 23000 lbs and 1957 sounds like an AC Forty Five. I found this Sell Allis Chalmer AD-40 Road Grader By Kennedy Equipment, USA1953 AC Grader AD-40 Road Grader Detroit Diesel Engine, 12 foot Moldboard with good edge, 13:00 x 24 Tires, Runs & Operates good. PRICE REDUCED |
DiyDave
Posted: 30 Aug 2018 at 6:15pm |
Per Swinfords book, I got the year wrong, they only made AD40"s from '52-'55. Weight is right, 23.000 lbs...
Ian Beale
Posted: 30 Aug 2018 at 6:33pm |
Hi Dave I thought Allis was out of Detroits around 1954? Or did they start using Budas? Next question - did the "Forty Five" come out 55 - 56 era then? If that book has serial numbers try 524 - 204 for a serial number. The "gotcha" is that is an Australian production number which makes reading a US parts book an interesting chore. By the "It has this but it doesn't have that" system I've got ours to within a couple of hundred. The Australian ones had Hydreco hydraulic pumps - must have been a licensee building them here I guess. This also turned up in the search - 6 reverse, 2 forward gears Edited by Ian Beale - 30 Aug 2018 at 6:36pm |
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 30 Aug 2018 at 7:11pm |
Ring gear on wrong side of pinion gear.
fishnhuntr
Posted: 30 Aug 2018 at 7:39pm |
Tag on left side of cab
Model AD-40 Serial number. 4070 One other tag has AD-40. 24 7 Found out it is 1950's Weigh about 18000# Appears to be 3-71 GM diesel. Power steering. Gear drive controls no hydraulic cylinders Any of this help to identify this ole girl?? |
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 30 Aug 2018 at 8:35pm |
I had a 1960 45 with 6 cyl. allis engine and jimmy supercharger. thanks ; ac fleet
Ian Beale
Posted: 30 Aug 2018 at 11:57pm |
The engine with supercharger was Lanova injection and might have just continued from what Buda was making when Allis bought them. If you're being a purist - with that engine it is a "Forty Five" (i.e. spelled) and the later ones with 10000 series engines are "45's (numeric). But most will get the idea with "45". A 1960 one might have been close to where they swapped to 10000 series engines? The supercharger might look like a GM but it is cast iron and made by Sweitzer - and heavy Edited by Ian Beale - 31 Aug 2018 at 12:04am |
kip in cny
Joined: 29 Nov 2009 Location: Jordan NY Points: 538 |
Posted: 02 Sep 2018 at 6:37pm |
It's a AD4 looks just like mine
160 CA 920diesel 5020 HD-3
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8980 |
Posted: 06 Sep 2018 at 1:58pm |
if it's a 40,it came out with a 4-71 Detroit. A 30 used the 3-71
