720 Won't Start
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: 720 Won't Start
    Posted: 29 Aug 2018 at 10:09am
I had been using my 720 throughout the day to pull my garden trailer around with tools in it and it had been running well and consistent.  I pulled up to the garage to get a couple items and left it running at low idle.  It died on me before I returned, but sat there only a minute or two with the key on and electric fuel pump running.   Wouldn't start, so I figured it was flooded.  Let it sit for a couple three hours, and still would not start.  Took air cleaner cover off and gas ran out.  Pulled it into the shed and tried the next day.  Still won't start.  It has now been three days, and it does not want to start.  Has spark, and obviously gas.  Any ideas?  Just really flooded and need to let it sit for an extended period of time?  Thanks for any input.  Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 10:42am
Pull your dipstick and check your oil level. Does it smell like gas??? Your electric fuel pump may have overwhelmed the float in your carb and the excess fuel is now in your crankcase, valve train. If so, drain your oil and replace with fresh oil. Fresh plugs may be needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 6:12pm
Well, went and checked and there is gas in the crankcase.  I'll drain it and put new oil in.  Darn, just changed oil in it a couple of hours ago.  Hope that solves the problem.  Hope it didn't do any additional damage.  Thanks, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 8:13pm
It shouldn’t have damaged anything since it wasn’t running. It will wipe the oil properties off all moving parts. Make sure you replace the filter also as it is probably full of gas as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 8:21pm
I would also pull the plugs and spin it over to see if it spits out fuel. May have also fouled the plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 9:17pm
Thanks.  Will get on it tomorrow.  Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 2:05pm
Well, it was raining today, so an inside job.  Changed the oil and filter.  Pulled plugs and turned it over with a little gas coming out one plug.  Cleaned the spark plugs.  Wouldn't even fire.  Tried ether in the air cleaner.  No fire.  Tried ether in the spark plug.  No fire.  I'm at a loss, now.  I'm not a carb guy, so hesitate to even to attempt to pull that off.  Any additional ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 8:30pm
Check to see if you have fire at the points. Might be points or condenser, could be coil. Check fire at coil first. Then go from there. My bet is points are problem. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 9:45am
It has spark at the plug, so wouldn't that indicate fire at the points?
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 9:48am
Did You Put In New Plugs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 9:53am
No new plugs.  Cleaned the old ones real good and checked the gap.  Just seems like it should at least try to fire when I use ether.  Going to get new plugs, though, and give that a try.  Thanks, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2018 at 9:36pm
Crazy as it sounds, new plugs will probably get you running again. My 720 was hard starting after blowing snow one winter. Had fire at the plugs, puzzled I replaced the plugs with new ones. Fired right up. If that doesn’t work, the coil may be at fault. Leaving the key turned on a non running engine can damage the coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2018 at 9:51pm
well, my plan is to get new plugs tomorrow and we'll see how that goes.  thanks for the suggestions and help.  Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2018 at 12:54pm
Tried new plugs.  Still no go.  Won't fire even with using some ether.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2018 at 10:42pm
Make sure both plugs are firing. The bad thing is you were not close to the machine when it stopped. So what caused it to stop? You know now that the electric fuel pump overpowered the needle in the carb as you found fuel in the crankcase. But why did it stop? I would start with the carb, take it apart and see that there is no junk in it. Check the float level. If nothing is found out of the ordinary, go to the points, condenser. They require attention every 100 hours. The Onans are finicky, timing also needs to be correct. After those items have been checked, the coil would be next. Also, check compression. Matter of fact check that first if you have the gauge to do so. My Onans do not like to idle for extended periods(beyond a minute), it seams they go rich on fuel as they will puff black smoke and cough until I give them some throttle. Just my 2cents.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2018 at 10:07am
Well, as it is beyond my ability level, I've made arrangements to take it to a local guy much more proficient in small engines to look at the carb and other potential issues mentioned here.  Is it necessary to reference any specific engine numbers or info when ordering a carb kit or other engine parts?  Where do you guys get your Onan parts?  Thanks again, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2018 at 8:49pm
Yes you will need the numbers listed on the left hand heat shield tag. Sandy Lake or Jacks Small engines has parts for the Onan. They are a great little engine but can be a finicky. I’m still running the stock fuel pumps on both of mine. 1,200 hours on one and 680 hours on the other and they are 42 years old. I did rebuild the pump on the 1,200 hour machine 7 years ago while I had the engine pulled so I could paint the entire tractor. Replaced the points also. A good shop should have you up and running in no time. Let us know what they find.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2018 at 9:26am
when you are checking the points check to see if the timing got changed  mine got loose and just died right in the garden  re timed it and fired right up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2018 at 12:15pm
A carburetor kit at Sandy Lake is $118.  Is that reasonable?  Just seemed on the high side, but if it is what I need . . . .
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2018 at 4:36pm
Check E-bay. I got one for my Zenith 13262 carburetor there for allot less. rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2018 at 9:31am
Well, got the carb kit put in.  Had to change oil and filter again as gas had leaked into the crankcase in the interim.  Got it to fire up and sounded pretty good just sitting there.  Got it home and tried it out driving it around.  At times, it wants to spit and sputter like it isn't getting gas and has an almost total loss of power.  Other times it will run pretty good.  Guess I'll just keep using it and trying it out to see how things go.  Thanks for all of the help.  Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2018 at 8:42pm
Did the person that worked on it check the points and timing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2018 at 8:56am
No, didn't mess with points or timing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2018 at 9:55am
Been driving the 720 around using it to pull the garden trailer to haul tools, branches, etc.  When it is first started up it sounds and runs very well.  If turned off and started again shortly (say 1 to 10 minutes) I've found it best not to give it full throttle and it runs pretty well.  If it sets for and extended period of time (hour or so) it starts up and runs well.  Guess I'll consider this pretty good for a 40 year old tractor and engine.  Thanks for all of the input and assistance.  Dave
This page was generated in 0.242 seconds.
