ground hog removal
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: ground hog removal
    Posted: 28 Aug 2018 at 10:31pm
seems like a ground hog has taken residence under the corner of my building. any thought of how to get rid of it.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2018 at 10:33pm
live trap and a 22 rifle worked for me the last few times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2018 at 11:12pm
what's it hurt'in?
Animal Cracker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Animal Cracker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 2:54am
what's it hurt'in?
Everything it wants to,especially if you have a garden.  Plus they dig holes and borough. And when you have one you'll get more. So unless you go over and talk it into leaving I'd kill'em or live trap it or get a dog.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 5:12am
[QUOTE=shameless dude]what's it hurt'in?[/QUOTE
Hey Shameless, most of us farmers would swap you a crate of groundhogs for a crate of snow in July for in your hay field or soybean field.Embarrassed Cry
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 5:39am
Conibear trap works for me unless you have critters that don't need to be eliminated. Never was able to catch a ground hog in a live trap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 5:54am
pour some diesel down a long section of 2" poly pipe , then a glug or 2 of gas. wait 2-3 minutes, then toss match at the hole.
If you get the 'mix' just right, the concussion from the explosion kills the critter, get it wrong, and well, corner of your house will need  a bit more than a 'lick of paint' to make it better.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 7:18am
Is that some diesel an exact measurement?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 8:09am
Gas it! Run a hose from an exhaust pipe into the borough, seal it up around the hose, then just wait a while. Killed a skunk that way using my G.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 8:48am
I thought someone on here, a while back, said to drop some bubble gum down the hole.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 11:30am
Organic fruit loops here were saying they liked Juicy FruitWink better. But we have squirrels that live in the ground like a groundhog but still just a squirrel.
But if you really want the cuteWink little bugger goneAngry I suggest stronger measures. Something like phostoxin tablets like you would put into stored grain to kill the bugs. Will not even have to fix the shed after the explosion some are wantingClap.  Just make sure you don't breath too much of itDead. But Creston's trik will do the same thing.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 1:53pm
I use gopher grenades. Get them at the hardaware store light it and drop in the hole cover with cardboard. It's just a smoke bomb that's deadly so don't breath it.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 1:58pm
#6 shot in a 20ga at 20 yards won't do it. Thought it did but he's back. He'll get 12ga if I can catch him out again. I'll have to check out the gopher grenades to.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 2:20pm
An 8 foot black snake might do the trick.
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 4:04pm
Keep a .22 handy and let the air out of it, quick, cheap, and easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 4:14pm
then....... how do you get rid of the snake !! Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 4:54pm
Farmer near me poured 5 gallons of water and 1 gallon of gas in a woodchuck hole and the resulting explosion his wife felt at the house saying the dishes were rattling around in the cupboard! The farmer told me he would not do that again as it was a way for an old man to kill himself! I have had success with hydrated lime or used cat litter poured down a hole. The woodchuck moves on and digs a new hole somewhere else. I have use road flares or the smoke bombs with varying degrees of success. Best success is shotgun,rifle or conibear trap
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 7:05pm
[TUBE]TESPsvwEZ0U[/TUBE]
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 7:17pm
Last one I removed was with a 22.  Hit him twice before he fell over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 9:04pm
[TUBE]BsCcX8jXA5k[/TUBE]
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 9:56pm
I put used cat litter in one hole in the machine shed they never opened that hole again. If i want to live trap them I try to set the trap so they have to run in, sometimes I set some wood or cardboard or another trap to guide them in.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 10:15pm
They were digging holes under our country church porch foundation. They were knawing holes up thru the floor. Minister pulled his 222 off the wall and out waited them. Us guys were sworn to secrecery, he didn't want the gals to know.
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 4:30am
When I was farming with my dad we had a hog operation which means lots of hog $hit. All week long as I would haul the manure to apply to the fields I would keep tract of the groundhogs I would see. If I had time on Sunday, only time you could hope for some time off, i would go to the creek and load up 1000 gal of water and get the dogs and head to the groundhog holes, didn't need to take a gun. Put the pipe in the hole and real soon out they came. One time a skunk and her young came out, we all scattered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 6:01am
I always thought it an expensive measure to kill a woodchuck as some Farmers would use Anhydrous Ammonia shooting that down the hole! Also could be dangerous for the operator! And I have had them tell me of using liquid cow manure to fill a hole.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 2:37pm
Had one dig two holes in the middle of the barn dirt floor.  I took 3" chlorine tablets used in swimming pools and broke them up into a few pieces and threw them down into the holes then covered them back up with dirt.  Will see on my next visit to farm if it kept them out of those holes.  They will take your breath away and maybe theirs.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 9:01pm
is that used cat litter or new cat litter?
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 9:41pm
Or was it a litter of cats?
ford8nwd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ford8nwd Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 7:06am
An apple in a live trap always worked for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 7:46am
Used Cat litter. As I told my Aunt ,I would move out of my hole if somebody dumped Cat Sh#t down it! Got another woodchuck last night with the conibear at my mother's house. That makes 4 so far.2 at the barn 2 at the house porch. They are this year's litter making their winter's home until they dug into me! I have been told Badgers eat woodchuck's . I would like a pet Badger!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 6:17pm
Problem wif badgers is that they might move inta the hole...
[TUBE]4r7wHMg5Yjg[/TUBE]
This page was generated in 0.176 seconds.
