Case 480C backhoe fuel tank? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10927 |
Topic: Case 480C backhoe fuel tank?Posted: 28 Aug 2018 at 9:51am |
Anyone here ever taken the metal sediment bowl off of fuel tank? Trying to clean tank on machine and not sure how bowl attaches. Any help appreciated. Thanks tracy
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35650 |
Posted: 29 Aug 2018 at 6:18am |
Most are pipe threaded into a boss built into the tank. Not certain on a Case, maybe do a parts lookup on the case site as to that section of fuel system.
DMiller
Posted: 29 Aug 2018 at 6:22am |
Decided had to look!!
https://partstore.casece.com/us/parts-search.html#epc::mr65625ar318907 Appears the sediment section is a component part of the tank, NON removeable. |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 29 Aug 2018 at 8:10am |
wow DUMB. bout like when they made the sc and dc tractors and then realized they needed a way to steer it. you see what they got.
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
Tracy Martin TN
Posted: 29 Aug 2018 at 10:33am |
I have the manuals. They don't show much as attaching. Does show 2 different tanks, at serial number change. I cleaned it off best I could. It appears to be soldered or welded to tank. The real question is, will tank come off with pulling engine or removing valve cover and rocker assy? I want to get the crap out of tank.Surely someone knows a good Case mechanic. Any previous know of this greatly appreciated. Thanks Tracy
