Question on HD16DC brake valve plumbing
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: Question on HD16DC brake valve plumbing
    Posted: 27 Aug 2018 at 8:55am
Hello Friends
A question that has had me wondering for a while now and just getting around to asking for opinions.
At the rear of my HD16DC looking at the two brake operating valves, the left side unit has a different hook up than the right and one that I cannot find in my original Operators, Parts or Service manuals that came with my tractor. Only the left side is hooked up this way and I'm wondering why as it does not appear to be original to the tractor and no manual bears it out. One of you may know whey this was done and I would really like to know your thoughts. Pics are below.
Thank you everyone.
Thank you again.
HD16DC, Bobcat 863 Turbo, Oliver 1855, John Deere 855,
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2018 at 9:04am
looks like a homebrew system to either vent both areas with the same breather or allow excess oil in the brake cylinder area to bleed back into clutch housing while still allowing said housing to be vented
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2018 at 9:55am
Thank you Cal. The right side does not have this and just has a steel plug in the housing. Would there be any benefit to this as on the surface I cannot see any. It's not stock and only one one side. Thinking of taking it out and see what it does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2018 at 12:43pm
your guess is as good as mine.  it was done for a reason
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2018 at 12:52pm
My 7G has housing breathers as that, someone did a pretty good re-engineer project there to vent the systems. Rubber lines would have worked as well or just adding another breather cap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2018 at 12:56pm
Another Minnpar parts book scan shows breathers at BOTH holes both sides. May have been knocked off in the past backing into something. Pages 172 and 210.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2018 at 6:51pm
Thanks everyone. Good ideas and points. I will likely add vents to both holes .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2018 at 8:22pm
Thank you. Will check it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2018 at 9:09am
Thank you DMiller for the reference. I looked it up and found that based on wether its a HD16 manual or HD16DC manual you get different pics on this. On the DC version it is showing breathers on the steering clutch as well as the final drive housing. I can't see the harm in adding the breathers rather than my copper snake method.
By the way, I put that copper line in as the one that was on the tractor when I bought it was cracked at the fitting and it was hard copper that was bent using a pipe bender. One solid piece and nicely done. I didn't have a pipe bender at the time so I soldered the pieces to get it done. Pretty janky looking I know but Im going to lose it and put on breathers for the final drive housings which is what I think the previous owners were trying to do.
thanks again everyone.
