Manifold Leak On B
George Davenport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Topic: Manifold Leak On B
    Posted: 26 Aug 2018 at 7:22pm
How do I check for a manifold gasket intake leak on my B?  I can not get it to idle smothly with the idle intake screw, and it runs rough a high speeds. The air cleaner-to-carb hose is not leaking. Thanks George
Life is what happens while you are making plans for the future
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2018 at 7:30pm
Spray some WD-40 around the manifold, if the intake part is leaking you should notice a change in rpm's. Carb cleaner or starting fluid will work also but are a lot more flammable.
