720 Hot indicator light.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: 720 Hot indicator light.
    Posted: 22 Aug 2018 at 7:18pm
The HOT light is supposed to go on if the hydro-stat oil gets hot.
Is it also supposed to come on during startup or cranking? How would one be made aware of a simple burned out bulb?
IH1650 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IH1650 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2018 at 7:56am
the light should come on when cranking. If not check bulb it may be burned out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2018 at 9:28am
Thank you. The light bulb was bad. I can't read any numbers on the bad bulb.
Now to find a replacement. Apparently the HOT and OIL bulbs are different.
Simplicity p/n is 172916, I think Allis P/N is 2028658-9. Anyone know what bulb to use from Napa or such.
Edit 8/25  The p/n I gave was not the bulb, but the light assembly, marked HOT. That explains why the OIL light is a different part number. I assume the OIL light bulb is also the 1895r.
Edited by BrianC - 25 Aug 2018 at 3:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote IH1650 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2018 at 5:40pm
Smile the bulbs are GE 1895R
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2018 at 6:59pm
Thank you guys.
This page was generated in 0.398 seconds.
