BC Belly Mount Sickle Mower
NormJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NormJ Quote  Post ReplyReply Direct Link To This Post Topic: BC Belly Mount Sickle Mower
    Posted: 19 Aug 2018 at 8:49pm
Does anyone know what the correct length of the pitman arm is supposed to be?
Thanks,
Norm
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 10:40am
I do not know even though I sold enough of them but the exact length of the pitman arm is critical to a successful mowing job.  I know cause there were two WC pitman rods for a side mower.  I sold a customer the wrong one and it caused him no end of problems.
He was nice about it but I NEVER FORGOT AGAIN.
Perhaps someone will add the information
Good Luck!
Bill Long
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 8:37pm
What measurement do you need?  Length of stick?  Center to center of pivot points?
I just took one off a 'B' today so I can measure what you need.
Edited by Alberta Phil - 20 Aug 2018 at 8:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NormJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 6:24pm
I will take both measurements if you have them.
Thank you.
Roger Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Mn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 6:34pm
you can buy them at tractor supply
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 6:41pm
Norm, the actual numbers from Phil will help........ but think about its function.. When the crank weight is all the way IN, the cutters are center inside the teeth.. When the crank weight is all the way OUT, the cutters are centered inside the NEXT TOOTH.
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 7:11pm
There is an adjustment if you loosen the nuts on the drag bar and the bolt yoke casting you can move it in or out to bring the sickle to register. It looks like the wood on my pitman stick is about 30&1/2'' hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2018 at 11:14am
Pitman stick on my mower is 26 inches long.  It's 34 1/4 inches from bearing center to bearing center.  Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NormJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2018 at 7:12pm
Thanks to all who posted replies. I have a few things to check on and will let you know how it turns out.
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2018 at 10:04am
once we are on the subject of mowers, can someone advise where I can find a pto pullyand a knife??
thanks in advance
John
This page was generated in 0.104 seconds.
